DiabloStinger
1000 Posts Club!
By now, if you are tuning and want to change your plugs, you probably ran across this video...
Here are a couple of tips from an install on a friend's stinger.
Driver's side is normal. Plenty of room to pull coils and plugs. You don't even have to disconnect the coils from their connectors.
Passenger side is a bit tighter and more challenging.
Tip one... Remove the first coil towards the front of the car. Unclip the connector, then remove the bolt holding it to the block. Remove the connector after lifting the coil up out of the cylinder far enough to get a couple fingers under so you can disconnect. Then remove that coil and plug.
Tip two. Remove the rear coil and plug second. You do not have to unclip this coil from the connector.
Tip three. Unclip the connector on the middle coil, then remove the bolt. You'll have to use a wrench or a 1/4" rachet on this on reaching under the intake manifold to get it moving .it's only held on by maybe 20 pounds of torque so it is easy. You now can work the coil out towards the back of the car slowly. Don't be alarmed if it comes apart into it's components as you remove it from the cylinder. Just don't lose any pieces or pull on it too hard.
You will be able to use your swivels to get the middle plug out.. I used the shortest extension you can buy. The socket is on the end, next the swivel, then the extension. I used a long extension to work it into the hole wiggling it a bit. Remove it and immediately out the new one in. Same process... Socket, swivel, short extension. Use the space under the manifold to direct the plug into the cylinder.
Tip Four.. you must install the middle coil before the front coil. Start it into the cavity facing the wrong direction (connector forward). Once you get it down into the cylinder you will be able to pivot into position.
You can now install the other coil and bolt it down.
Hope this helps. This took as long as the normal method since we had to figure out a way to get that second coil back in.
I would inagine this takes 45 minutes tops knowing what I know now.
Ask me any questions you have. I am blessed with eidetic memory when it comes to things like this
