worse....Connecticut.
The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
we have 8 seasons ,not four!! arctic,winter,wet,spring,tropical,summer,desert,fall.......Oh is it that bad??
uh, almost 2 monthsHow long have u had your stinger?
I cringe when I see a decent car totally abused....good comments already about good gas, injector cleaner, synth oil, etc.
All add that to keep rust away (winter regions), I rinse out in the wheel wells as often as I can given the cold temps
Normal basics of cleaning bird poop off paint quickly, sap, etc
catch cans seem like a prudent step
Glad to hear folks that like to keep cars in good condition. These are nice cars whether you keep them for 15yrs or sell to the next owner, should be kept in good order.
uh, almost 2 months
He must think you're an ace driver!I’m in MA and the dealer told me with awd there’s no need for winter tires. I’ve always had winter tires. Not sure what to do any feedback welcomed - thanks
Should I wait to Krown it after the paint settles in? Or should I go and do it right away?
- Read and understand the owner's manual
- Follow maintenance schedule religiously
- Change oil rather more than less
- Don't cheap out on consumables (oil, coolant, AT fluid etc)
- If something needs to be looked after, do it sooner than later.
- Keep her clean.
- Get her rustproofed (Krown or RustCheck in Canada)
- Make an effort to find a good mechanic.
- Don't race her unnecessarily.
Should I wait
Your paint is cured. So there is no problem there. If this car is your DD, get it done before the snow flies.
I had my mechanic take the undercover panels off before I took the car for its treatment. That will enable the technician to spray everywhere.
There are six panels and cover probably 80% of the car's belly, and obscure too much if you want the rust treatment done properly.
I also used this as an opportunity to clean, degrease, paint and wax the panels. In addition, bought 25 stainless 5mm bolts with washers & lock washers to replace the
OEM hardware, because it is prone to rust...
I had a Fumoto valve installed during my first oil change @ 800km, and now with the panels down cut an access port for the valve into the panel under the engine.
Copied the design from the front panel's port for the oil filter change and made a cover for it.
I had bought an OEM cover from the dealer ($6), but it did not work as well, because the opening I cut is not specifically stamped as is the original.
Made the cover then from very thin alu plate & spacer. Wanted to keep it as light as possible.
Things to think about. Good luck.![]()
kindly explain
There is no rule that you HAVE to rust proof your car immediately after purchase. If you drive a clunker in the winter, you could wait until next Fall. But if you need to drive it through the worst season of the year, why not protecting it while everything is "fresh"?
Firstly, get PPF on all of your chromed parts, bumper, hood, A-pillars, door sills and the rear bumper. I would do that before the Krown (or RustCheck as in my case) treatment. Saves on a lot of cleaning before the film goes on. Do the wax after the PPF.
I suggest you take possession of the car with the panels already off. Let the dealer do it. Explain why.
The panels are fixed with a combination of bolts and plastic clips. The OEM (self-threading) bolts have lock washers & washers incorporated. Keeps the parts from getting lost I guess.
If I am not mistaken, there are a total of 25 bolts for the six panels. No need to get self-threading ones. The clips don't rust. I don't know what you mean by lugs. Anyway, put everything back once the dripping stopped.
You should update your profile with your location.
that bar
What bar?
I make you work first.
You can use my "handle" and "Fumoto valve" and search the forum for it. Many moons ago I provided this information together with the picture of the item.
The Fumoto website may also take you to the proper item.
I have a valve where the direction of the oil stream can be changed. 14 mm is the thread.
The oil plug location on a vertical surface at the back of the engine. Very straightforward.
Always double check the facts yourself, never take anyone's word for it.
appreciate it
You are welcome.
One last thing: Have you considered proper tires for the season to come?
And before you ask, I took delivery of the car very early in January and had ordered a set of Michelin Pilot Sport A/S 3 a week prior to expected delivery. Drove the car from the dealer directly to Costco to facilitate the transfer. I am very happy with them.
