lozic tcu with jb4 tune?
I don’t know how any rwd stingers are getting under 4 seconds 0to60 times.I have tcu tune JB4 borla exhaust secondary cats gone. Tork intakes. Bms intercooler. Run 100 octane gas. 275 35 19 on rear 4s I leave with 8 pounds of boost and spin for 100 feet . What is the secret.
These things are tork monsters with just rear wheel drive . Know grip.and my runs where turned down from map 4 to 3 . Spin baby spin
better surface, leave with less boost. it builds so quickly in these cars that the increased traction is worth it for RWD.
The problem it doesn’t build any boost if you don’t have tcu tune. I’ve tried it all ran a 4.1 on map 2. And that was spinning letting out and getting back into it. I know the car is fast. Have beat tune supras c7 stingrays chargers challengers mustangs. But all rolling. I’ve had car five years never been able to get grip off line. Just wondering what I’m doing wrong. Seeing all these crazy 0to60 times on dragy. I don’t get those on my dragy. Just wondering
Im aware. I have the Tork TCU tune as well. its all about timing. your RPMS need to be lower. 8lbs is usually around 2500 to 2600rpm, so try at 2400rpm, also make sure your road is in good condition, not dust/dirty or whatever. also, shift your gears at 5500, then 5700, 5700 again for the first 3 gears to stay in the prime power band.
Hell I’ve been letting the trans do all the shifting. So all these runs are in manually mode. I roll race in manually mode. But when I try it off the line it goes through first gear so fast I usually hit the chip and car falls on face.
have your fingers on the paddles before you release the brake, that way when it crosses the 5500 mark and you click the paddle, it will shift around 5800 instead of hitting the lowered limiter.
Yep I’ll try that. I’m in south Florida all are roads are all pretty good. Plus I need back end tune on ecu Im pretty sure I’m hitting tork limits and throttle is closing between shifts
reply with a log from your JB4, I can tell you if thats the case or not.
Yep
Firmware,Interface,Engine,TMAP_V,AvgIgn,DWP,MethTriggerMode,FF,MethSafeMode,MethAdd,MethScale,MethPSI,VIN,E85_Setup,VFF_Offset,,fuel_30,fuel_35,fuel_40,fuel_45,fuel_50,fuel_55,fuel_60,fuel_65,fuel_70
21/6//5,JB4 iOS 8513,Infiniti/Other,1.6,0.0,0,0,0,0,0,0,0.0,5LC7J6012920,0,150,,0,0,0,5,10,20,60,80,80
BoostSafety,PID Gain,AutoShiftRed,Fuel_OL,FUA,1st_limiter,2nd_limiter,3rd_limiter,FUD,N20_TMAP,6CylMode,LastSafety,,duty_15,duty_20,duty_25,duty_30,duty_35,duty_40,duty_45,duty_50,duty_55,duty_60,duty_65,duty_70
3.0,0,0,60,0,0.0,0.0,0.0,0,0,0,0,,0,0,0,0,0,0,0,0,0,0,0,0
timestamp,rpm,ecu_psi,target,boost,pedal,iat,fuelen,wgdc,throttle,fp_h,ign_1,avg_ign,calc_torque,trims,dme_bt,meth,fp_l,afr,gear,ff,load,clock,map,afr2,ign_2,ign_3,ign_4,ign_5,ign_6,oilf,waterf,transf,e85,boost2,trims2,mph
0.00,611,0.1,0.0,0.1,0,134,0,0,13,3,2.0,0.0,0,22.0,0.0,0,0,14.8,0,0,0.0,6,2,14.5,0.0,0.0,0.0,0.0,0.0,0,215,0,0,0.0,22.0,0
3.75,607,0.1,0.0,0.1,0,134,0,0,13,3,1.0,0.0,0,22.0,0.0,0,0,14.8,0,0,0.0,6,2,14.4,0.0,0.0,0.0,0.0,0.0,0,215,0,0,0.0,22.0,0
5.00,608,0.1,0.0,0.1,0,134,0,0,13,3,2.0,0.0,0,22.0,0.0,0,0,14.8,0,0,0.0,6,2,14.4,0.0,0.0,0.0,0.0,0.0,0,215,0,0,0.0,22.0,0
6.50,602,0.1,0.0,0.1,0,134,0,0,13,3,1.0,0.0,0,22.0,0.0,0,0,14.8,0,0,0.0,6,2,14.4,0.0,0.0,0.0,0.0,0.0,0,215,0,0,0.0,22.0,0
8.00,607,0.1,0.0,0.1,0,134,0,0,13,3,1.5,0.0,0,22.0,0.0,0,0,14.8,0,0,0.0,6,2,14.4,0.0,0.0,0.0,0.0,0.0,0,215,0,0,0.0,22.0,0
9.00,605,0.1,0.0,0.1,0,134,0,0,13,3,1.0,0.0,0,22.0,0.0,0,0,14.8,0,0,0.0,6,2,14.4,0.0,0.0,0.0,0.0,0.0,0,215,0,0,0.0,22.0,0
10.25,608,0.1,0.0,0.1,0,134,0,0,13,3,1.0,0.0,0,22.0,0.0,0,0,14.8,0,0,0.0,6,2,14.4,0.0,0.0,0.0,0.0,0.0,0,215,0,0,0.0,22.0,0
13.00,610,0.1,0.0,0.1,0,134,0,0,13,3,1.5,0.0,0,22.0,0.0,0,0,14.8,0,0,0.0,6,2,14.4,0.0,0.0,0.0,0.0,0.0,0,215,0,0,0.0,22.0,0
15.75,608,0.1,0.0,0.1,0,134,0,0,13,3,0.5,0.0,0,22.0,0.0,0,0,14.8,0,0,0.0,6,2,14.4,0.0,0.0,0.0,0.0,0.0,0,215,0,0,0.0,22.0,0
16.75,606,0.1,0.0,0.1,0,134,0,0,13,3,1.5,0.0,0,22.0,0.0,0,0,14.8,0,0,0.0,7,2,14.4,0.0,0.0,0.0,0.0,0.0,0,215,0,0,0.0,22.0,0
18.25,612,0.1,0.0,0.1,0,134,0,0,13,3,2.0,0.0,0,22.0,0.0,0,0,14.8,0,0,0.0,7,2,14.4,0.0,0.0,0.0,0.0,0.0,0,215,0,0,0.0,22.0,0
19.75,608,0.1,0.0,0.1,0,134,0,0,13,3,1.0,0.0,0,22.0,0.0,0,0,14.8,0,0,0.0,7,2,14.4,0.0,0.0,0.0,0.0,0.0,0,215,0,0,0.0,22.0,0
21.00,607,0.1,0.0,0.1,0,134,0,0,13,3,1.0,0.0,0,22.0,0.0,0,0,14.8,0,0,0.0,7,2,14.5,0.0,0.0,0.0,0.0,0.0,0,215,0,0,0.0,22.0,0
23.75,603,0.1,0.0,0.1,0,134,0,0,13,3,0.5,0.0,0,22.0,0.0,0,0,14.7,0,0,0.0,7,2,14.5,0.0,0.0,0.0,0.0,0.0,0,215,0,0,0.0,22.0,0
26.25,608,0.1,0.0,0.1,0,134,0,0,13,3,0.5,0.0,0,22.0,0.0,0,0,14.7,0,0,0.0,6,2,14.5,0.0,0.0,0.0,0.0,0.0,0,215,0,0,0.0,21.0,0
27.75,607,0.1,0.0,0.1,0,134,0,0,13,3,0.5,0.0,0,22.0,0.0,0,0,14.5,0,0,0.0,6,2,14.5,0.0,0.0,0.0,0.0,0.0,0,215,0,0,0.0,21.0,0
30.50,610,0.1,0.0,0.1,0,134,0,0,13,3,0.5,0.0,0,22.0,0.0,0,0,14.5,0,0,0.0,6,2,14.6,0.0,0.0,0.0,0.0,0.0,0,215,0,0,0.0,21.0,0
31.75,603,0.1,0.0,0.1,0,134,0,0,13,3,0.0,0.0,0,22.0,0.0,0,0,14.5,0,0,0.0,6,2,14.6,0.0,0.0,0.0,0.0,0.0,0,215,0,0,0.0,21.0,0
33.00,606,0.1,0.0,0.1,0,134,0,0,13,3,1.0,0.0,0,22.0,0.0,0,0,14.5,0,0,0.0,6,2,14.6,0.0,0.0,0.0,0.0,0.0,0,215,0,0,0.0,21.0,0
34.50,604,0.1,0.0,0.1,0,134,0,0,13,3,0.5,0.0,0,22.0,0.0,0,0,14.5,0,0,0.0,6,2,14.6,0.0,0.0,0.0,0.0,0.0,0,217,0,0,0.0,21.0,0
35.75,605,0.1,0.0,0.1,0,134,0,0,13,3,0.5,0.0,0,22.0,0.0,0,0,14.5,0,0,0.0,6,2,14.7,0.0,0.0,0.0,0.0,0.0,0,217,0,0,0.0,21.0,0
37.00,602,0.1,0.0,0.1,0,134,0,0,13,3,1.0,0.0,0,22.0,0.0,0,0,14.5,0,0,0.0,6,2,14.7,0.0,0.0,0.0,0.0,0.0,0,217,0,0,0.0,21.0,0
38.50,604,0.1,0.0,0.1,0,134,0,0,13,3,0.5,0.0,0,22.0,0.0,0,0,14.5,0,0,0.0,6,2,14.7,0.0,0.0,0.0,0.0,0.0,0,217,0,0,0.0,21.0,0
39.50,603,0.1,0.0,0.1,0,134,0,0,13,3,0.0,0.0,0,22.0,0.0,0,0,14.5,0,0,0.0,6,2,14.7,0.0,0.0,0.0,0.0,0.0,0,217,0,0,0.0,21.0,0
42.50,602,0.1,0.0,0.1,0,134,0,0,13,3,0.0,0.0,0,22.0,0.0,0,0,14.4,0,0,0.0,6,2,14.7,0.0,0.0,0.0,0.0,0.0,0,217,0,0,0.0,21.0,0
43.75,600,0.1,0.0,0.1,0,134,0,0,13,3,1.0,0.0,0,22.0,0.0,0,0,14.4,0,0,0.0,6,2,14.7,0.0,0.0,0.0,0.0,0.0,0,217,0,0,0.0,21.0,0
45.00,602,0.1,0.0,0.1,0,134,0,0,13,3,2.0,0.0,0,22.0,0.0,0,0,14.4,0,0,0.0,6,2,14.7,0.0,0.0,0.0,0.0,0.0,0,217,0,0,0.0,21.0,0
46.25,601,0.1,0.0,0.1,0,134,0,0,13,3,2.0,0.0,0,22.0,0.0,0,0,14.4,0,0,0.0,6,2,14.7,0.0,0.0,0.0,0.0,0.0,0,217,0,0,0.0,21.0,0
47.75,606,0.1,0.0,0.1,0,134,0,0,13,3,0.5,0.0,0,22.0,0.0,0,0,14.4,0,0,0.0,6,2,14.7,0.0,0.0,0.0,0.0,0.0,0,217,0,0,0.0,21.0,0
48.75,608,0.1,0.0,0.1,0,134,0,0,13,3,1.0,0.0,0,22.0,0.0,0,0,14.4,0,0,0.0,6,2,14.7,0.0,0.0,0.0,0.0,0.0,0,217,0,0,0.0,21.0,0
50.25,604,0.1,0.0,0.1,0,134,0,0,13,3,0.5,0.0,0,22.0,0.0,0,0,14.4,0,0,0.0,6,2,14.7,0.0,0.0,0.0,0.0,0.0,0,217,0,0,0.0,21.0,0
54.25,598,0.1,0.0,0.1,0,134,0,0,13,3,1.0,0.0,0,22.0,0.0,0,0,14.4,0,0,0.0,6,2,14.7,0.0,0.0,0.0,0.0,0.0,0,217,0,0,0.0,21.0,0
55.50,602,0.1,0.0,0.1,0,134,0,0,13,3,1.0,0.0,0,21.0,0.0,0,0,14.4,0,0,0.0,7,2,14.7,0.0,0.0,0.0,0.0,0.0,0,217,0,0,0.0,21.0,0
57.00,601,0.1,0.0,0.1,0,134,0,0,13,3,1.5,0.0,0,21.0,0.0,0,0,14.4,0,0,0.0,7,2,14.7,0.0,0.0,0.0,0.0,0.0,0,217,0,0,0.0,21.0,0
58.25,600,0.1,0.0,0.1,0,134,0,0,13,3,1.5,0.0,0,21.0,0.0,0,0,14.4,0,0,0.0,7,2,14.8,0.0,0.0,0.0,0.0,0.0,0,217,0,0,0.0,21.0,0
61.00,602,0.1,0.0,0.1,0,134,0,0,13,3,0.5,0.0,0,21.0,0.0,0,0,14.5,0,0,0.0,7,2,14.8,0.0,0.0,0.0,0.0,0.0,0,217,0,0,0.0,22.0,0
62.50,620,0.1,0.0,0.1,0,134,0,0,13,3,0.5,0.0,0,21.0,0.0,0,0,14.5,0,0,0.0,7,2,14.7,0.0,0.0,0.0,0.0,0.0,0,217,0,0,0.0,22.0,0
65.25,722,0.0,1.1,0.0,49,136,0,0,44,4,4.0,0.0,0,21.0,0.0,0,0,14.6,0,0,0.0,6,2,14.7,0.0,0.0,0.0,0.0,0.0,0,217,0,0,0.0,22.0,0
66.75,1257,0.0,1.1,0.0,50,136,0,0,58,7,14.0,0.0,0,20.0,0.0,0,0,14.5,0,0,0.0,6,2,14.6,0.0,0.0,0.0,0.0,0.0,0,217,0,0,0.0,19.0,0
68.25,1966,0.0,1.1,0.0,50,136,0,0,78,7,17.0,0.0,0,20.0,0.0,0,0,14.5,0,0,0.0,6,2,14.1,0.0,0.0,0.0,0.0,0.0,0,217,0,0,0.0,19.0,0
69.50,2167,0.2,1.1,0.2,50,136,0,0,82,10,17.0,0.0,0,23.0,0.0,0,0,15.0,0,0,0.0,6,2,14.1,0.0,0.0,0.0,0.0,0.0,0,217,0,0,0.2,22.0,0
71.25,2298,1.5,1.1,1.2,50,136,0,0,84,10,15.5,0.0,0,25.0,0.0,0,0,15.3,0,0,0.0,6,2,15.0,0.0,0.0,0.0,0.0,0.0,0,217,0,0,1.2,24.0,3
74.25,2467,3.8,1.1,4.5,50,136,0,0,86,10,11.0,0.0,0,27.0,0.0,0,0,15.0,0,0,0.0,5,2,15.1,0.0,0.0,0.0,0.0,0.0,0,217,0,0,4.6,26.0,9
76.00,2720,6.0,1.4,6.9,54,136,0,0,89,10,11.5,0.0,0,28.0,0.0,0,0,15.6,0,0,0.0,5,2,15.0,0.0,0.0,0.0,0.0,0.0,0,217,0,0,7.0,29.0,11
77.75,3099,9.4,1.6,10.4,54,136,0,0,95,10,9.5,0.0,0,28.0,0.0,0,0,15.6,0,0,0.0,5,2,15.8,0.0,0.0,0.0,0.0,0.0,0,217,0,0,10.5,29.0,11
79.00,3553,12.7,1.7,13.9,54,136,0,0,96,11,7.0,0.0,0,33.0,0.0,0,0,13.9,0,0,0.0,5,2,15.8,0.0,0.0,0.0,0.0,0.0,0,217,0,0,14.0,33.0,15
80.75,4467,9.9,1.9,12.1,56,136,2,0,99,10,0.0,0.0,0,36.0,0.0,0,0,13.9,0,0,0.0,5,2,14.7,0.0,0.0,0.0,0.0,0.0,0,217,0,0,12.3,35.0,19
82.50,4899,8.2,1.7,10.7,56,136,6,0,99,11,3.0,0.0,0,36.0,0.0,0,0,12.3,0,0,0.0,5,2,13.9,0.0,0.0,0.0,0.0,0.0,0,217,0,0,9.9,34.0,25
84.00,4929,3.6,1.2,10.7,49,136,2,0,73,11,3.0,0.0,0,36.0,0.0,0,0,12.3,0,0,0.0,5,2,12.1,0.0,0.0,0.0,0.0,0.0,0,217,0,0,9.9,34.0,25
87.50,4542,8.0,5.0,12.4,80,134,6,0,92,10,1.0,0.0,0,34.0,0.0,0,0,13.5,0,0,0.0,5,2,12.9,0.0,0.0,0.0,0.0,0.0,0,217,0,0,12.5,34.0,29
89.25,3702,11.2,5.0,16.0,72,134,2,0,99,10,11.0,0.0,0,41.0,0.0,0,0,19.1,0,0,0.0,5,2,13.9,0.0,0.0,0.0,0.0,0.0,0,217,0,0,16.2,44.0,30
90.50,4031,13.1,5.0,17.4,78,134,0,0,99,10,9.0,0.0,0,41.0,0.0,0,0,19.1,0,0,0.0,5,2,18.8,0.0,0.0,0.0,0.0,0.0,0,217,0,0,17.3,44.0,30
92.00,4443,11.5,5.0,16.8,73,134,2,0,99,10,9.5,0.0,0,44.0,0.0,0,0,13.1,0,0,0.0,5,2,18.8,0.0,0.0,0.0,0.0,0.0,0,217,0,0,17.4,44.0,35
93.75,4655,12.2,4.9,17.4,70,134,6,0,99,11,10.0,0.0,0,44.0,0.0,0,0,12.7,0,0,0.0,6,2,13.0,0.0,0.0,0.0,0.0,0.0,0,217,0,0,17.7,44.0,38
95.50,5009,12.1,4.5,16.7,70,134,6,0,99,10,12.5,0.0,0,44.0,0.0,0,0,12.0,0,0,0.0,6,2,12.5,0.0,0.0,0.0,0.0,0.0,0,217,0,0,16.6,42.0,40
97.25,5193,11.9,4.3,16.3,68,134,10,0,99,11,12.0,0.0,0,42.0,0.0,0,0,11.7,0,0,0.0,6,2,11.7,0.0,0.0,0.0,0.0,0.0,0,217,0,0,16.5,40.0,43
99.00,5409,10.6,4.1,15.5,68,134,14,0,99,11,12.5,0.0,0,41.0,0.0,0,0,11.3,0,0,0.0,6,2,11.4,0.0,0.0,0.0,0.0,0.0,0,217,0,0,16.0,37.0,45
102.25,5768,10.0,4.0,14.3,66,132,22,0,99,11,13.0,0.0,0,38.0,0.0,0,0,11.8,0,0,0.0,6,2,11.7,0.0,0.0,0.0,0.0,0.0,0,219,0,0,15.2,36.0,50
103.50,6021,10.2,4.0,14.0,66,132,27,0,99,11,13.0,0.0,0,38.0,0.0,0,0,11.8,0,0,0.0,5,2,11.8,0.0,0.0,0.0,0.0,0.0,0,219,0,0,14.4,36.0,50
105.25,6141,9.7,4.0,13.8,66,131,32,0,99,11,13.5,0.0,0,38.0,0.0,0,0,11.8,0,0,0.0,5,2,11.8,0.0,0.0,0.0,0.0,0.0,0,219,0,0,14.0,36.0,52
106.75,5447,11.3,4.1,15.3,66,131,35,0,99,11,0.0,0.0,0,35.0,0.0,0,0,11.8,0,0,0.0,5,2,11.8,0.0,0.0,0.0,0.0,0.0,0,219,0,0,15.7,34.0,54
108.50,4668,12.1,4.8,17.4,61,131,29,0,99,10,9.5,0.0,0,37.0,0.0,0,0,12.3,0,0,0.0,5,2,11.8,0.0,0.0,0.0,0.0,0.0,0,219,0,0,17.5,34.0,56
110.25,4702,12.7,4.8,17.4,61,129,24,0,99,10,10.0,0.0,0,37.0,0.0,0,0,12.3,0,0,0.0,5,2,12.3,0.0,0.0,0.0,0.0,0.0,0,219,0,0,17.7,33.0,56
111.75,4751,12.9,4.8,17.2,59,129,19,0,99,10,10.5,0.0,0,36.0,0.0,0,0,12.2,0,0,0.0,5,2,12.3,0.0,0.0,0.0,0.0,0.0,0,219,0,0,17.5,34.0,60
115.25,4926,13.0,4.5,17.2,49,129,9,0,99,10,11.0,0.0,0,37.0,0.0,0,0,11.9,0,0,0.0,5,2,12.0,0.0,0.0,0.0,0.0,0.0,0,221,0,0,17.2,33.0,64
116.75,5068,9.8,4.4,17.2,38,129,12,0,99,10,11.0,0.0,0,37.0,0.0,0,0,11.9,0,0,0.0,5,2,11.7,0.0,0.0,0.0,0.0,0.0,0,221,0,0,17.2,33.0,64
118.25,4618,8.5,4.9,14.6,0,125,9,0,23,10,0.0,0.0,0,36.0,0.0,0,0,11.6,0,0,0.0,5,2,11.5,0.0,0.0,0.0,0.0,0.0,0,221,0,0,14.1,31.0,66
120.00,4087,3.9,5.0,6.6,0,125,4,0,19,8,36.5,0.0,0,18.0,0.0,0,0,11.0,0,0,0.0,5,2,11.5,0.0,0.0,0.0,0.0,0.0,0,221,0,0,0.0,13.0,65
121.50,3876,3.0,5.0,3.6,0,125,0,0,19,8,19.0,0.0,0,18.0,0.0,0,0,12.7,0,0,0.0,5,2,11.1,0.0,0.0,0.0,0.0,0.0,0,221,0,0,0.0,14.0,65
124.25,3636,1.6,5.0,1.8,0,123,0,0,19,6,19.5,0.0,0,18.0,0.0,0,0,13.1,0,0,0.0,5,2,13.7,0.0,0.0,0.0,0.0,0.0,0,221,0,0,0.0,15.0,65
126.00,3625,1.1,5.0,1.2,0,123,0,0,18,5,17.5,0.0,0,18.0,0.0,0,0,13.5,0,0,0.0,5,2,14.3,0.0,0.0,0.0,0.0,0.0,0,221,0,0,0.0,25.0,65
129.00,3533,0.8,5.0,0.8,0,123,0,0,21,5,15.5,0.0,0,25.0,0.0,0,0,3.8,0,0,0.0,5,2,14.3,0.0,0.0,0.0,0.0,0.0,0,221,0,0,0.0,25.0,64
130.50,3657,0.7,5.0,0.7,0,123,0,0,21,5,16.5,0.0,0,25.0,0.0,0,0,3.8,0,0,0.0,5,2,15.2,0.0,0.0,0.0,0.0,0.0,0,221,0,0,0.0,25.0,64
131.75,3548,0.6,5.0,0.7,0,122,0,0,21,5,15.5,0.0,0,25.0,0.0,0,0,3.8,0,0,0.0,6,2,3.8,0.0,0.0,0.0,0.0,0.0,0,221,0,0,0.0,25.0,64
133.25,3406,0.6,0.0,0.6,0,122,0,0,21,5,15.5,0.0,0,25.0,0.0,0,0,3.8,0,0,0.0,6,2,3.8,0.0,0.0,0.0,0.0,0.0,0,221,0,0,0.0,25.0,63
134.50,3286,0.6,0.0,0.6,0,122,0,0,20,5,15.5,0.0,0,25.0,0.0,0,0,3.8,0,0,0.0,6,2,3.8,0.0,0.0,0.0,0.0,0.0,0,221,0,0,0.0,25.0,63
137.25,3095,0.5,0.0,0.5,0,122,0,0,20,5,14.5,0.0,0,25.0,0.0,0,0,3.8,0,0,0.0,6,2,3.8,0.0,0.0,0.0,0.0,0.0,0,222,0,0,0.0,25.0,63
138.75,2958,0.5,0.0,0.5,0,122,0,0,20,6,14.5,0.0,0,25.0,0.0,0,0,3.8,0,0,0.0,6,2,3.8,0.0,0.0,0.0,0.0,0.0,0,222,0,0,0.0,25.0,63
140.00,2883,0.5,0.0,0.5,0,120,0,0,19,6,14.0,0.0,0,25.0,0.0,0,0,3.8,0,0,0.0,6,2,3.8,0.0,0.0,0.0,0.0,0.0,0,222,0,0,0.0,25.0,63
141.50,2868,0.4,0.0,0.4,0,120,0,0,19,6,14.0,0.0,0,25.0,0.0,0,0,3.8,0,0,0.0,6,2,3.8,0.0,0.0,0.0,0.0,0.0,0,222,0,0,0.0,25.0,63
142.50,2852,0.5,0.0,0.4,0,120,0,0,19,6,14.0,0.0,0,25.0,0.0,0,0,3.8,0,0,0.0,6,2,3.8,0.0,0.0,0.0,0.0,0.0,0,222,0,0,0.0,25.0,63
144.00,2921,0.5,0.0,0.4,0,120,0,0,19,6,14.0,0.0,0,25.0,0.0,0,0,3.8,0,0,0.0,6,2,3.8,0.0,0.0,0.0,0.0,0.0,0,222,0,0,0.0,25.0,63
145.50,2942,0.4,0.0,0.4,0,120,0,0,19,6,14.5,0.0,0,25.0,0.0,0,0,3.8,0,0,0.0,6,2,3.8,0.0,0.0,0.0,0.0,0.0,0,222,0,0,0.0,25.0,62
148.00,2921,0.4,0.0,0.4,0,120,0,0,19,6,14.5,0.0,0,25.0,0.0,0,0,3.8,0,0,0.0,6,2,3.8,0.0,0.0,0.0,0.0,0.0,0,224,0,0,0.0,25.0,62
149.50,2908,0.3,0.0,0.4,0,120,0,0,19,6,14.0,0.0,0,25.0,0.0,0,0,3.8,0,0,0.0,6,2,3.8,0.0,0.0,0.0,0.0,0.0,0,224,0,0,0.0,25.0,62
151.00,2776,0.4,0.0,0.4,0,118,0,0,19,6,13.0,0.0,0,25.0,0.0,0,0,3.8,0,0,0.0,6,2,3.8,0.0,0.0,0.0,0.0,0.0,0,222,0,0,0.0,25.0,62
152.25,2550,0.3,0.0,0.3,0,118,0,0,19,6,11.0,0.0,0,25.0,0.0,0,0,3.8,0,0,0.0,6,2,3.8,0.0,0.0,0.0,0.0,0.0,0,222,0,0,0.0,25.0,62
153.50,2373,0.3,0.0,0.3,0,118,0,0,19,6,11.0,0.0,0,25.0,0.0,0,0,3.8,0,0,0.0,6,2,3.8,0.0,0.0,0.0,0.0,0.0,0,222,0,0,0.0,25.0,61
155.00,2261,0.3,0.0,0.3,0,118,0,0,19,6,9.0,0.0,0,25.0,0.0,0,0,3.8,0,0,0.0,6,2,3.8,0.0,0.0,0.0,0.0,0.0,0,222,0,0,0.0,25.0,61
156.00,2252,0.3,0.0,0.3,0,118,0,0,18,6,9.0,0.0,0,25.0,0.0,0,0,3.8,0,0,0.0,6,2,3.8,0.0,0.0,0.0,0.0,0.0,0,224,0,0,0.0,25.0,61
157.50,2255,0.3,0.0,0.3,0,118,0,0,18,6,9.0,0.0,0,25.0,0.0,0,0,3.8,0,0,0.0,6,2,3.8,0.0,0.0,0.0,0.0,0.0,0,224,0,0,0.0,25.0,61
160.25,2291,0.3,0.0,0.3,0,118,0,0,18,6,9.0,0.0,0,25.0,0.0,0,0,3.8,0,0,0.0,6,2,3.8,0.0,0.0,0.0,0.0,0.0,0,222,0,0,0.0,25.0,60
161.50,2352,0.3,0.0,0.3,0,118,0,0,18,6,10.0,0.0,0,25.0,0.0,0,0,3.8,0,0,0.0,6,2,3.8,0.0,0.0,0.0,0.0,0.0,0,222,0,0,0.0,25.0,60
163.00,2358,0.3,0.0,0.3,0,118,0,0,18,6,10.0,0.0,0,25.0,0.0,0,0,3.8,0,0,0.0,6,2,3.8,0.0,0.0,0.0,0.0,0.0,0,222,0,0,0.0,25.0,60
164.25,2347,0.2,0.0,0.3,0,118,0,0,18,7,10.0,0.0,0,25.0,0.0,0,0,3.8,0,0,0.0,6,2,3.8,0.0,0.0,0.0,0.0,0.0,0,222,0,0,0.0,25.0,60
165.50,2337,0.2,0.0,0.2,0,118,0,0,18,7,10.0,0.0,0,25.0,0.0,0,0,3.8,0,0,0.0,6,2,3.8,0.0,0.0,0.0,0.0,0.0,0,222,0,0,0.0,25.0,60
167.00,2332,0.2,0.0,0.2,0,118,0,0,18,7,9.5,0.0,0,25.0,0.0,0,0,3.8,0,0,0.0,6,2,3.8,0.0,0.0,0.0,0.0,0.0,0,222,0,0,0.0,25.0,60
168.25,2326,0.2,0.0,0.2,0,118,0,0,18,7,9.5,0.0,0,25.0,0.0,0,0,3.8,0,0,0.0,6,2,3.8,0.0,0.0,0.0,0.0,0.0,0,222,0,0,0.0,25.0,59
170.75,2315,0.2,0.0,0.2,0,118,0,0,18,7,9.5,0.0,0,25.0,0.0,0,0,3.8,0,0,0.0,6,2,3.8,0.0,0.0,0.0,0.0,0.0,0,222,0,0,0.0,25.0,59
Well, TBH, I could actually read that if I wanted to take the time,
Go to your logs, Click on one, hit email, email it to yourself, then go to the email, download the file, then if youre on a computer, click attach file and find the log file you downloaded, then hit upload.
Presto, its uploaded here.
My car falls on face between 1 2 shifts am I hitting my tork limits. Anyone else having that problem tork tcu with JB4 map 3 or 4 race gas.
Does anybody have a TCU tune for sale? Looking for a used one because I don’t have the extra $800 laying around lol. I have a GT2 AWD.
Torkmotorsports will do tcu tunes for 99 bucks go to there website send them your tcu. You are taking about transmission tune
All the tcu tunes you have to send out tcu or buy extra one for 500
