Mike_TX
Oh Em Gee. The adjustment made a world of difference. I drove around tonight and I kept expecting people to flash me, but no one did. lol.
World of difference!
This just saved my butt after installing the eibach springs. THANK YOU!After installing my springs my headlights were aimed lower. This has been an easy fix on other cars I’ve owned but the Stinger is slightly different.
First the headlight adjustment is behind the headlight on each side under where the fender and hood meet.
Generally there is a screw to adjust the height, and this hole that’s circled has a marking saying U<—>D, seems like a logical place.
The other hole says L<—>R but there is nothing in the hole. I’ve never had a reason to adjust a headlight left to right though.
I have the K&N intake and I just had to unbolt the heat shield and remove the filter to get to the adjustment. The stock system should be easy as well as you would just need to remove the air filter box which I think is just 3 bolts and a hose clamp.
This is what is down that hole. Glad I just purchased an WiFi endescope to get this picture. Obviously that’s not a screw.
Luckily on the back side of this “gear” is a 12mm nut. It’s marked by the arrow in the top picture.
Park the car in front of a wall/garage door and turn on the lights, mark your starting location with something. I like to use painters tape.
Rotate the nut using a crescent wrench (ratcheting makes this much easier) and see which way the beam moves. If it goes up, keep going. If it goes down, go the other direction. It’s a tight fit so you’ll only get maybe 1/10 a rotation before hitting the frame and it’s a fine adjustment so the 1” I moved the beam took 1 - 1 1/2 rotations of the nut.
Sorry to bump an older thread, but I came across this issue as well (low headlamp aim) so I wanted to contribute for anyone reading in the future:
I work in the automotive lighting industry. I was shocked at how low the aim was on the factory GT2 (adaptive) lamps. The cutoff (flat portion at the top of the pattern) shines about 50-60 feet in front of the vehicle, on a flat road. I have seen a lot of bad factory aiming, usually it is too high. But in the Stinger, driving at night is miserable with the factory aim.
In general terms, FMVSS/DOT aiming and beam pattern standards call for that top of the cutoff to be parallel - that is, it should shine to the horizon on a perfectly level surface. The factory aim on my 2018 GT2 was at least 4-6 degrees lower than it should be, which makes a HUGE difference in distance of the headlamp beam.
To aim the headlamps properly, park on a perfectly level surface with the car at least 20 feet from a wall. Look at your headlights - you will see a small dot in the center, molded into the plastic. This is intentional, indicating the optical center for aiming. Use a tape measure and determine how far off the ground that dot is. If it's 30 inches, go to the wall and measure 30 inches up. The top of the cutoff should be 30 inches up as well. If you lower your Stinger by 2", as long as it's even all around, your aim should NOT change! But it's always a good idea to re-aim when you do any kind of suspension change as it could alter how the vehicle sits.
Anyone consider that the proper adjustment tool would be something like a #24 torx on a long shaft?
I have a 2021 Stinger Gt. The low beam is dangerously low, especially when turning to the left (In Australia we drive on the left hand side of the road, so the beam to the left of the road shines higher to avoid dazzling oncoming drivers) When turning right, the dynamic bending lights adjust to send the higher left hand side beam to the centre of the road, but when turning left the opposite occurs, making visibility dangerously short.After installing my springs my headlights were aimed lower. This has been an easy fix on other cars I’ve owned but the Stinger is slightly different.
A snuggly fitting screwdriver shank is probably not getting all the way seated in the worm gear. If you use a screwdriver with a thinner shank so that it has some play inside the access hole, you'll get a better feel for how the screwdriver tip is engaging with the gears.I have a 2021 Stinger Gt. The low beam is dangerously low, especially when turning to the left (In Australia we drive on the left hand side of the road, so the beam to the left of the road shines higher to avoid dazzling oncoming drivers) When turning right, the dynamic bending lights adjust to send the higher left hand side beam to the centre of the road, but when turning left the opposite occurs, making visibility dangerously short.
I have found the two adjusting screws (as shown in previous post), and a No2 Phillips screwdriver fits snugly into the funnel shaped guide to engage the phillips head screw. The screw was initially hard to turn, almost felt like it was spring loaded, but once started and worked in either direction, it turns quite easily. However, no matter how much I turn the screw, the headlight low beam remains in the same place. I have turned each side screw about a dozen turns anticlockwise to raise the beams, but nothing changes.
Any ideas?
No, unfortunately that's not the case. The guide in the funnel shaped piece guides the screwdriver perfectly into the phillips head screw and I can feel it turning. in the case of the l--r funnel for lateral adjustment, it's the same and I can actually watch the screw and plastic 12mm nut turning. I tried the next sized driver down and it's a loose fit in the screw so there is a risk of stripping the phillips slot (the screw requires mild force to turn).A snuggly fitting screwdriver shank is probably not getting all the way seated in the worm gear. If you use a screwdriver with a thinner shank so that it has some play inside the access hole, you'll get a better feel for how the screwdriver tip is engaging with the gears.
Better at 25 feet away and tape height set at 24 inchesBumping this as a thank-you - hadn't been driving at night much since being lowered but I've had to do it more recently and I was reacquainted with the super-low aim. Got this knocked out in 5 mins with a screwdriver and some tape on the inside of the garage door. Aimed both sides up a little over an inch from point blank range and went for a drive, definitely much better but maaaybe a little too high. The few cars I passed didn't flash me, but I'll try to find a spot where I can test it on a flat surface from 20' to get it right.
I've found that the exact height of the cutoff is irrelevant (i.e. you don't need to know it to set the lights. As long cutoff is at the same height from 10', 20', 50', or whatever, you're maximizing light distance while assuring you're not blinding anyone. This method also removes any variability due to lowering springs.Where are you guys finding 20'+ of flat surface? Seems any minor indentation in the road surface throws the beam many degrees off.
agree to disagree.....the ''cutoff'' can still be way too high and blind on coming traffic ....so height is very relevant. I completely understand the situation you describe, but the lights still need to be ''aimed'' otherwise , why have an adjustment screw at all?I've found that the exact height of the cutoff is irrelevant (i.e. you don't need to know it to set the lights. As long cutoff is at the same height from 10', 20', 50', or whatever, you're maximizing light distance while assuring you're not blinding anyone. This method also removes any variability due to lowering springs.
