How To Adjust Headlight Beam Height
Discussion in 'Kia Stinger How To's and Do It Yourself' started by DaJackson, May 19, 2018.
  1. DaJackson
    DaJackson United States 1000 Posts Club!
    1,589
    669
    Louisiana
    After installing my springs my headlights were aimed lower. This has been an easy fix on other cars I’ve owned but the Stinger is slightly different.
    First the headlight adjustment is behind the headlight on each side under where the fender and hood meet.
    Generally there is a screw to adjust the height, and this hole that’s circled has a marking saying U<—>D, seems like a logical place.
    The other hole says L<—>R but there is nothing in the hole. I’ve never had a reason to adjust a headlight left to right though.
    I have the K&N intake and I just had to unbolt the heat shield and remove the filter to get to the adjustment. The stock system should be easy as well as you would just need to remove the air filter box which I think is just 3 bolts and a hose clamp.
    This is what is down that hole. Glad I just purchased an WiFi endescope to get this picture. Obviously that’s not a screw.
    Luckily on the back side of this “gear” is a 12mm nut. It’s marked by the arrow in the top picture.
    Park the car in front of a wall/garage door and turn on the lights, mark your starting location with something. I like to use painters tape.
    Rotate the nut using a crescent wrench (ratcheting makes this much easier) and see which way the beam moves. If it goes up, keep going. If it goes down, go the other direction. It’s a tight fit so you’ll only get maybe 1/10 a rotation before hitting the frame and it’s a fine adjustment so the 1” I moved the beam took 1 - 1 1/2 rotations of the nut.
    • Like x 7
    • Informative x 5
    • Useful x 4
    • Agree x 1
    • Winner x 1
    • Optimistic x 1
  2. Fl stingergt
    Fl stingergt United States Stinger Enthusiast
    671
    110
    So clockwise to raise. Right
  3. DaJackson
    1,589
    669
    Louisiana
    I honestly don’t remember. Once you start rotating it you will see it move, if it’s the wrong way go the other direction.
  4. Fl stingergt
    671
    110
    Ya the spring change deafeningly shorten up light distance. Even with drop these springs ride better then stock to me.
  5. Fl stingergt
    671
    110
    Counter clockwise raises light. Just finished doing it very easy all back to normal.
  6. JCranford83
    JCranford83 United States Member
    33
    37
    Lancaster, PA
    What model do you have?
  7. Fl stingergt
    671
    110
    I have gt rear wheel. It is super easy to adjust lights 15 min
  8. Fl stingergt
    671
    110
    Take out air boxes three bolts. Take off tube. You will see bolt head. I think 12 mm go counter clockwise to raise. Put tape on wall wait until dark. I went up about ten inches above tape put it back to normal before springs
  9. JCranford83
    33
    37
    Lancaster, PA
    Dealer said no adjustment option on GT2. Ugh.
  10. DaJackson
    1,589
    669
    Louisiana
    The GT2 has auto leveling headlights correct? They should still have an adjustment. My VW leveled up and down and left and right but still had adjustment screws.
    You should be able to feel behind the headlight where the bolt should be without removing the air boxes.
    • Like Like x 1
  11. Fl stingergt
    671
    110
    Look under hood on wheel well behind light there is a plastic grey they look like little funnels . Adjusting but on bottom. There is know side to side adjustments. Just up and down
  12. Fl stingergt
    671
    110
    I would double check what kia said
  13. JCranford83
    33
    37
    Lancaster, PA
    What do I stick in the funnel...screwdriver? And How did the Kia tech not see that????
  14. DaJackson
    1,589
    669
    Louisiana
    Go look at the top post again, there is a gear in that funnel and at most you can move it fractions of a mm if you get a screwdriver down there.
    Adjusting the bolt is much easier and more efficient.
    • Agree Agree x 1
  15. Fl stingergt
    671
    110
    Nothing down hole look underneath there is a nut head spin it counter clockwise to raise. Some of these guys and girls selling and working on have know idea of what’s going on with this car and how to do stuff to them. When I bought mine I knew more about car then anybody in there.
    • Like Like x 1
    • Agree Agree x 1
    • Informative Informative x 1
  16. Fl stingergt
    671
    110
    Go back few days on this thread there are pictures of bolt head under plastic funnel looking thing
  17. Fl stingergt
    671
    110
    Did you get your lights adjusted
  18. JCranford83
    33
    37
    Lancaster, PA
    Not yet...was going to try Fri but it was pouring rain...then landed in ER most yesterday. Going to try this week.
  19. MicroBlue
    MicroBlue United States Active Member
    120
    Indianapolis, IN
    This post should be part of a FAQ or Sticky! Great work and write up @DaJackson
    • Like Like x 1
  20. Mach_Tuck
    Mach_Tuck United States 1000 Posts Club!
    1,029
    273
    88
    Phoenix, AZ
    Agreed, perhaps moved to the DIY section...i verified same gears in mine and located the adjustment bolt right where @DaJackson OP showed.
    • Like Like x 1
Draft saved Draft deleted
Share This Page
