thefultonhow
Whether the new rotors are made of a different material which isn't prone to build up of pad material, or the original rotors were Warped as the master tech said, I don't know.
What I do know is this, there is absolutely no valid reason to spend money on after market pads or rotors to accommodate normal diving conditions.
Just because the problem hasn't recurred with the new rotors doesn't mean the problem was the rotors. It just means you haven't driven the car hard enough since then to cause pad deposits to transfer to the new rotors.
Drive down a mountain, dragging your brakes the whole way, and then apply them firmly while stopped at the bottom, and I guarantee the issue will recur.
BTW, all rotors, except $10,000+ carbon-ceramic ones on exotic cars, are made of carbon steel. There is no coating of other material -- it would just wear off.
The reason I am suggesting to check the part numbers on your front rotors is that the Brembo (j5500) and non-bembo (j5000) are similar. When my rotors were replaced, the tech said the part numbers on the originals were not clear. He said it was possible the non-brembo rotors were installed on my car during the manufacturing process.
Okay, first of all, there is no "J5000" part number. The part number for the non-Brembo rotors are 58110J5010. The ones for the Brembo rotors are 58110J5500BCR (old) and 58110J5510BCR (new).
Secondly, the "J5010" rotors are the ones from the base 2.0T Stingers with 17" wheels. They literally would not fit on a GT with Brembo calipers. They're too small, by a lot.
Sorry, your explanation doesn't hold up.
