Angel
1000 Posts Club!
yes those would work perfect, man.Would the "K&N RG-1001RD" filter work any better since it has the additional top cone?
They're about the same price here in Canada ($40->$45 CAD)
That's the existing pipe from the stock air box. Just the chrome pipe is added.Those considering this, if you've not test-removed the passenger side airbox yet, you might do so. The rubber piping that runs from the new, Spectre 90 degree elbow to the turbo is corrugated, for lack of a better term. It "flops" around a bit. Putting the elbow and a fancy filter on it is going to need some support sooner rather than later, IMHO.
I’m 99% sure that’s just a warning not to use it for turbo or supercharger connections. They wouldn’t be able to withstand the high boost pressure directly from a turbo, but they are made for intake piping. They’re specifically designed for intake connections and are intended to be used under the hood. Heat shouldn’t be a factor and if you’re concerned just use a insulated heat shield like I did.Just getting ready to order these and seen the 90 elbows say not for use with turbo charged or super charged applications. View attachment 10502
Can someone confirm these are the correct elbows.
This is a great alternative if you prefer K&N, but it looks exactly the same as the Spectre version we’re using. It also has the additional top cone leading into the filter so it draws air from the top and sides. Actually, this is another reason I chose the Spectre over the standard K&N. More filter media and air from multiple directions means much more airflow!Would the "K&N RG-1001RD" filter work any better since it has the additional top cone?
Yes, and it's "floppy". Bracing, again IMHO, is very much needed.That's the existing pipe from the stock air box. Just the chrome pipe is added.
The stop pipe is rotated (optional) to face forward, or can remain sideways like in the original post and have no impact on that monitor hose.
Unless I'm looking at the wrong hose, which is very possible and highly likely.
Agreed and another reason why I didn’t reinstall my intakes until I got the perfect brackets. I also used the stock airbox mount & screw so it was an easy install.Yes, and it's "floppy". Bracing, again IMHO, is very much needed.
Did you not buy the 90 degree elbows? Can you show me a pic of what you did?Agreed and another reason why I didn’t reinstall my intakes until I got the perfect brackets. I also used the stock airbox mount & screw so it was an easy install.
I’m not sure where you can mount brackets using the 90 elbow, but hopefully they can find somewhere. Good luck all and keep up the good work!![]()
Lol. I’m the OP and suggest reading the whole thread. Lots of helpful information with my pics and videos starting at post #1.Did you not buy the 90 degree elbows? Can you show me a pic of what you did?
You can see I chose the straight intake pipe(3”x2”) so I could use the stock mounts for my brackets. That also made it easy to wrap the heat shielding below & around the filters.
The elbow intake is a different DIY version and we’re all just brainstorming ideas so that one works well too.
Hope this helps and happy tuning!
Lol sorry man I have read the entire thing and didn’t realize who I was asking. I’m going to be doing this soon I hope. Gotta get Kia to repaint her first!
@Sabz Slightly off topic, but I was told by Kia that they are recalling both Yellow and Blue soon globally... They have pulled the blue off the lots apparently
@StungBlueGT2 I couldn't see the brackets in the pics did you just use a modified straight pipe bracket?
I bought the 90's, but I'm yet to do the install.
Look at post #14. It has more pics and a description of the brackets, intake tubing, etc.@StungBlueGT2 I couldn't see the brackets in the pics did you just use a modified straight pipe bracket?
Guys moment of truth i will work on custom shield tonight !!!! wish me luck videos will be posted soon adn pics....
Im like 30 min east of lakemoor so im like an hour to an hour an a half away.LOL hahaha were are you located bro?? i am on rockford IL
Thats not bad I used to work on Mchenry IL, yeah man I will let you know for sure man....I would not mind some Stinger companionship lol ... thats cool men i leave sunday on vacation to puerto rico....we should defensively link up...send you phone number on a pm please and name i will text you with my number so you can have....there arent that many stinger owners near me .....Im like 30 min east of lakemoor so im like an hour to an hour an a half away.
