Chris71
Authorized Vendor
- May 8, 2019
Do you have a sound clips? I had issues with my intake and it ended up being air escaping under pressure, one mechanic thought it was the wastegate, one thought it was the ECU not controlling the vacuum correctly, both were wrong, it was a bad worm clamp and weak silicone coupler. I switched to tbolts and new coupler and issue was fixed.So I use the bent elbows with mine... so how do I fix this wastegate issue ? Does it cause any problems ? Not like I can go to a dealer and say hey my aftermarket intake is sounding strange can you look at it haha .... I never heard it under stock box as you don’t hear the blow off sound
		 I think the normal additional noise sounds good, u can wrap the hood and reduce some if you want.
