Cell phone holder placement
Discussion in 'Kia Stinger Interior Discussion' started by bugaboo90, Feb 14, 2018.
  1. SEA Stinger
    SEA Stinger United States Active Member Sustaining Member
    428
    255
    68
    Seattle, Washington
    • Like Like x 1
  2. robsat
    robsat United States Newish Member
    Sorry if I missed where this has already been discussed. Has anyone tried to mount a suction cup to the back of the display monitor and then adjust the length of the arm and rotate the part that holds the phone in place so the whole thing with the phone attached comes out just to the left of the screen? I would think (don't own one to know) that a mount like the one pictured earlier in the thread by Kazz might just work. From there the charging cord could naturally hang from the phone and go to the USB AUX plug with little problem and less clutter. Thoughts?
    Edit: I tried to link to the cell holder Kazz pictured but kept getting a spam error.
  3. MikeJr74
    MikeJr74 United States Member
    81
    40
    Sebastian, Florida
    $10 Walmart solution. Bought the magnetic vent clip mount. Unscrewed the unit and removed the vent tabs. Applied double face tap to the back of the magnetic base and stuck to the dash. Works great for my Pixel 2XL. I have a USB cable in the power tray that I plug into the phone when driving, to use Android Auto. Holds extremely well. Phone has not moved, even when using launch mode.
    The magnetic plate is attached to my belt clip holder. So, I put the phone in the holder backwards when on the dash. The placement does not interfere with the push button nor the air vent. 2018-09-07 12.52.37.jpg IMG_20180907_125209.jpg IMG_20180907_125220.jpg
  4. EBdiesel08
    EBdiesel08 United States Active Member
    115
    26
    New York City
    I actually did a modification, I got it from a YouTube video SGt and me. I drilled a hole in the center console, and by the cover where you connect the usb for Apple car play. It’s so much better. You have to lift up the plastic where the shifter is.
  5. AV8R
    AV8R Australia 5000 Posts Club! Staff Member Authorized Vendor Moderator
    • Agree Agree x 1
  6. EBdiesel08
    115
    26
    New York City
    Ok I only did it bc I plan to keep the car. It’s def a good fix if you change your mind. I’m not a big diy person, but I was able to do it. Sorry this doesn’t help.
  7. AV8R
  8. Collybus
    Collybus United States Member
    38
    12
    Quincy Massachusetts
    Before I saw that there is a whole thread devoted to this, I posted my solution elsewhere IMG_0733.JPG IMG_0728.JPG IMG_0729.JPG . I didn't want to cover any of the instruments, wanted to have the phone easily accessible because okay sometimes I may text a little bit while driving, and so also didn't want it easily seen from other cars. This is an iOttie articulating mount that is stuck and suctioned onto the piece of plastic on the console by the glovebox. Seems to work perfectly so far!
  9. SteveCo
    SteveCo Canada Stinger Enthusiast
    952
    350
    68
    Calgary, AB
    And your phone is mounted so you are looking down at the floor while doing so? Sorry, but that is scary as hell ... :thumbdown:
  10. Get Stung
    Get Stung United States Active Member
    I put mine here. BMS $15 never fallen off.
    • Like Like x 1
  11. Kazz
    Kazz United States 1000 Posts Club! Texas Stinger Swarm
    1,248
    429
    88
    Illinois
  12. Get Stung
    About a month ago,
    JB4 Magnetic Cell Phone Mount - BurgerTuning.com
    As a bonus in this position I can fire up the cell phone camera and take vids while I'm driving/racing.
  13. Kazz
    1,248
    429
    88
    Illinois
    Dashcam...
    Interesting. Thanks!
  14. Namuna
    Namuna United States Member
    39
    12
    NJ
    Just ordered this along with a couple of 1ft long USB cables to go from the phone to the port.
    It really sucks that you can't charge the phone at the same time as having Android Auto running (well, technically the charge battery icon comes on, but my charge rate app shows it's only charging at about 140mA which is a joke).
  15. Namuna
    39
    12
    NJ
    Well, that was $25 wasted. I couldn't get it stay on the dash (maybe I'll try the leaving it on the dash for a few days trick, but the more I think about it the less I like leaving something on the dash over time to have a discoloration later). Even if it did stick (whether to dash, or on the windshield) I've got a Galaxy Note9 and when it's on the mount it's high enough to be an annoying view obstruction.
    I'm going to give the magnetic cup holder a go...Does anyone know if the metal plate that you put on the phone/case interferes with wireless charging?
  16. mcemc
    mcemc United States Newish Member
    11
    Louisiana
    I know this isnt a cell phone question but I carry a pistol with me and looking for the best place to put it for easy access. I had a ford f150 and would put it between the seat. Not able to now. Was wondering if anyone carries and found a good place.
    • Like Like x 1
  17. STINGER
    STINGER Bahrain Active Member
    407
    214
    Bahrain
    Wireless charging
  18. MikeJr74
    81
    40
    Sebastian, Florida
    I keep my 9mm in the arm rest. It and my sunglasses case fit perfectly.
    • Like Like x 1
  19. EBdiesel08
    115
    26
    New York City
    I purchased a magnet on amazon and placed it below the push to start but close to the steering wheel.
  20. mcemc
    11
    Louisiana
    What magnet if I can ask I am very curious about this.
Draft saved Draft deleted
Share This Page
