ScottE
What magnet if I can ask I am very curious about this.
Probably a magnetic phone mount - they are pretty common, and better than the old edge clamp type, but require a specific case for the magnet to attract, I think.
The majority of the ones I've seen recently come with a thin metal 'plate' that is either adhered to the back of the phone or the inside of your existing case.Probably a magnetic phone mount - they are pretty common, and better than the old edge clamp type, but require a specific case for the magnet to attract, I think.
10$ solution
3M tape.Does it use a suction cup or some sort of adhesive where the bass mounts to the dash?
Well, I unpacked the mount again (I had packed it back up to prepare for returning it) and figured I'd give it another shot. I ended up finding a much better spot, I'm not a big fan of items on my dashboard and I hate clutter, so this position for me works perfect. rear side panel of the center console which is plastic so the suction/mount adheres to it perfectly. check the photos out.
View attachment 3703 View attachment 3704 View attachment 3705
I know this isnt a cell phone question but I carry a pistol with me and looking for the best place to put it for easy access. I had a ford f150 and would put it between the seat. Not able to now. Was wondering if anyone carries and found a good place.
I made several different attempts at finding a device that was reachable, easy to view, unobtrusive and wouldn't have to be glued or stuck somewhere that would leave a noticeable ghost behind after removal. I also didn't want anything hanging from the windshield. 3 different people received 'gifts' which were my failures at satisfying the above criteria. This is what I settled on:
It sits in the perfect height and position in my opinion. And since I'm alone in the car 99% of the time, the loss of one cup holder spot isn't an issue.
View attachment 3222 View attachment 3223
Wow finally. Only took them 2 years. Wonder why it claims to be only compatible with the 2019s though...
I normally use the weather tech cup holder phone holder when I’m alone, if I need to use both cup holders I have a mount in that spotI'm tentatively looking at the seemingly flat (although not level) surface just to the left of the display panel. Hoping a suction-cup mount could attach there.
I need this. This is my solution. I can't find this holder anywhere, anyone know where one can procure this?
Yup. $30 for the mount for the car, then $20-30 for the phone holder. It's supposed to be a two part solution since you can swap phone mounts that specifically fit your phone without having to get a mount that specifically fits your dash/car. $30 one-time and $20 or so for a phone-specific holder when you get a new phone.So $30 for just the mount and it doesn't include a holder? Take a look at the install procedures to see what you are paying for.
Pass.
Agreed re quality and stability. I already have the holder anyways from my prior solution, so this will be a no brainer for me.Yup. $30 for the mount for the car, then $20-30 for the phone holder. It's supposed to be a two part solution since you can swap phone mounts that specifically fit your phone without having to get a mount that specifically fits your dash/car. $30 one-time and $20 or so for a phone-specific holder when you get a new phone.
They're also much better quality than most of the ones you find on Amazon. I think they're worth it.
Excellent and about time. Will wait to see how it looks with different phone setups.
It's not really $60 for a single phone mount though. It's $30 for the car piece, then $20-30 per phone you get. Most people get new phones before new cars. You don't have to replace the phone holder part when you change your phone.Yeah and still no. If you think $60 is a good price for a single phone mount that's up to you. It is an option.
