Revvdmedia
1000 Posts Club!
I hear you.
The logs will be useful too so you can look at timing advance in cyl 1-6 under the same conditions for both fuels. If the performance is similar but one fuel has better timing.. It's a good indication to stick with that fuel.
Yes I have looked at timing and you have seen a few of my logs. I always felt overall timing could be a little higher by about 4 or 5 degrees usually but timing drops happened on all 6 cylinders equally, you noted that pulling timing due to knock usually happens on particular cylinders, not consistently on all 6, so I've been thinking it may or may not be octane, hard to say.
