Legendsk
Anyone have any tips to getting a good connection through the fuse into the module? If I run it through the fuse it doesn't work but using the cigarette adapter works. I'm guessing i'm not getting a good connection in there. This is my first attempt at powering anything in my car through the fuse so I could just not understand fundamentally how it works. Am I to wrap the exposed wire around a single fuse leg or both? Should I somehow wedge it so it gets pushed in with the fuse? Any tips would be helpful, thanks!
The lighter socket has both +12v and ground. You will have to find an empty fuse slot with +12v switched, so it will be off when the ignition is off AND another empty fuse slot for ground and run both wires to your light(s). {Using the taps in the above link.}
Of course, if there is a good frame ground near your light connection, you can use that and only run a +12v wire from the fuse box, from just one of those taps.
