soulevo8
I was replying about why the gauges don't work. I've never had a code, even when I cracked a plug, so I have no experience with that.
not sure what that is. I didnt install this.
It has fuel wires.
so I'm fishing the wire through the firewall to the jb4 unit?There is a little tail already on the JB4 ready to connect to this wire. It should be right next to the main one in the grommet.
That's the no-boost issue some members mentioned on the n54 forum. V4 firmware was supposed to remedy it. Are you on v4?
Yes so far I'm running the v4 firm and ran map 5 at the track yesterday and still no boost problem knock on wood and fingers crossed
@Terry@BMS Just wanted to say that even if "the other guys" look for "inspiration" on your findings (which I totally understand where you are coming from) your customer support and willingness to improve on the platform is second to none. That is the cherry on top of the excellent product you have developed. Wish more vendors offered the same support and were as active as you have been on these boards.
Keep up the great work.
I still dont have this connected? Does this affect performance on map 2 with 93?OBDII is required for the gauges to work and the fuel control won't turn on without OBDII as well.
Yes. If you don’t have the OBDII connected then the fuel wires are useless and you’re missing out on a noticeable amount of extra power.I still dont have this connected? Does this affect performance on map 2 with 93?
