bumble bee
1000 Posts Club!
Nydito, Alot I know that. Fill us in on the intake.
Wow, good eye dude.
- Dyno tested with and without enclosures: no horsepower drop with enclosures installed, enclosures smoke tested to ensure proper utilization of airflow from OE intake ducts
The test person that has it tells me it’s fully closed box and they had K&N before.
Yeah, and it's a pretty big gap too. See photo below.
The intake wouldn’t be an intake of it didn’t use the ducts. I am no performance parts manufacturer, and I know the intakes need to get air from the ducts. Stillen has a very good rep and has been around a long time, they know how to make intakes, I have no doubt it uses the ducts. But I’ll let you know in 2 weeks. Ha!The gap is so large because the sides of the radiator shroud aren't installed.
But I agree about the ducts like. I'm really interested to see how the Stillen boxes use them since both Stillen and Khar have said they are in fact used to bring fresh air in. I'm still a bit skeptical since I can't see them in the pics of the installed intake and the the pics of the intake parts don't look to have any cutouts for the ducts to pipe into.
That part is sealed. My understanding is that the only opening is the one you see on the top near the side of the car.So I was looking at my JT intakes earlier, and was going to put the boxes around the filters that it came with finally... then it hit me....
The turbos need to be blocked from the filter. The sides and rear of the filter in the KIA are the most critical sides that need blocking. Blocking the top and front is pointless imo.
The top area can just use a simple peice of weatherstrip and compresses agaisnt the hood. Easy. heres a mock up of the stillen picture.
If they can achieve a complete seal of the area and locations marked in red, I will def. try it out.View attachment 10934
Seems the Stillen intake needs this JT modification. If the box was fully sealed it should act like a stock airbox with a high flow filter. I suspect it does pull extra air from the gaps. I also trust their dynos, the 343 hp stock on a dyno jet is spot on. I'm very suspect of other vendors that show 365 hp stock and take credit for the 20hp under rating.
