That looks great. How much did it set you back? Where's the AMG?
I am definitely curious to see a follow up on that.
I want to do a dash cam, but I have no idea where to begin looking, or for what.
Some follow-up:
We took a road trip this week and there is some buzzing (when driving over rough road) coming from the new dash cam. I need to take it off when I get home and see about securing the wiring with some tesa tape to quiet it down.
The bigger concern is that my wife couldn't connect to the camera AT ALL with her iphone. I had the same issue with my Android for a bit but then I was able to connect again later on down the road.
When I reconnected, all the video was saved there of course but not being able to access it on the fly via a cell phone is not how it's supposed to work. At least if I can eliminate the buzzing noise that will be a big relief.
What trunk LED strip is that? Link? :laugh:
It was very inexpensive but considering the price the quality is great. 10 min install, it just tucks behind the rubber seal then cut the excess. It taps into the wire for the trunk LED so turns on and off the same.
Hardest bit was getting the led lense cover out to tap the wire once the wire is fed behind the lining but it's easy when you know how.
$351 for the car cover...
Installed this new steering wheel tonight.
Got it from someone on eBay. (New by Jalisco Carbon Fiber)
The heating function isn't as good as stock but it is functional.
The heater wiring was coming the opposite way from stock so I had to do a bit of wire rerouting.
Other than that, no issues installing it. Amazed at just how super easy to R&R vs my other car that requires a wheel puller to remove
Bought a boot mat for it...
Cream interior? what spec do you have?
^ not sure if mine is a unicorn but my requirements were a white -23 gt2 with as low miles as I could find that was near me.
This one fit the bill only 1 state away with 7800 miles and the beige interior. I thought I wanted a black interior but actually fell in love with the beige so it all worked out in the end
I thought that color interior only came on the green.
Honestly I thought beige only came on the lower trims. Hmmm unicorn forsure, looks real good tho!
Edit: Is it nappa leather or vinyl?
Here's the window sticker the dealer emailed to me after purchase:
