Coasting mode
Agreed. We are talking about battery voltage here, as it relates to the battery open circuit SoC (state of charge).
Typically, yes, but our cars have some subsystems which ONLY work if the battery SoC is above X%.
ISG (Idle Stop and Go) for example, requires a minimum of 78% SoC for it to operate - so a weak or an uncharged battery will cause this system to stop working, with no fault codes. It is merely a condition of operation.
Kia Stinger: Engine Control / Fuel System / ISG (Idle Stop and Go) (Idle Stop & Go) System - (Search for SoC)
Also - several people are hypothesizing that the ECO coast function may require a min SoC in order to function, though finding any documentation supporting this is proving to be difficult.
100% correct, not disconnected via a clutch, but there is reduced voltage output based on driving conditions + battery state of charge.
When the car knows the battery has a high SoC, the AMS alternator management system, can reduce the voltage/load while cruising, and increase the voltage/load while decelerating.
The no-load resting voltage really is "supposed" to be a reliable method to determine SoC.
Based on my cars build date (Feb 2018) - my battery is at least 2141 days or 70 months or 5.9 years old, so my open circuit resting voltage of 12.1v may be correct/expected for its age.
additional data from my 2018 stinger with OEM 90Ah AGM battery
During cranking, at 2°C (36°f), my voltage dips down to 8.2v - still cranks strong :thumbup:
Starting an already hot engine with coolant temp at 93°C (199°f), voltage dipped to 9.2v.
2018 stinger with OEM 90Ah AGM battery - Car build date was 02/2018
That is a lot of great information.
So provided the voltage output of the alternator remains constant at say 14 volts thereabouts, as the battery reaches this voltage the current starts to back off from the alternator. This happens with all batteries and alternators, so when the battery is fully charged all the alternator is supplying is the load and maintaining a trickle into the battery.
There could be an argument to back the voltage off on the alternator once these conditions are met.
Yep. When a battery does a heavy discharge i.e high current drain for short periods, you can take the end voltage much lower per cell. So typically 1.6 volts per cell or even 1.5 volts per cell (9V). That's because the current only comes off the surface of the plates so you have not "discharged" a significant number of amp hours from the cell and, you can put back a 10 second heavy discharge rather quickly with the alternator over say 10 -15 minutes.
So you can do lots of things with a car battery. You can discharge it over say 10 hours with a light load but you have to finish at a higher end voltage to not damage the battery. That's where you extract the most amp hours, or you can discharge the battery with a high current for a short period to a lower end voltage and that doesn't damage the battery like turning a starter motor for example. You get much lower amp hours out of the battery though under those conditions and It could be rated as little as 20 amphours using it like that even though it says 90 ah, 100Ah. That's a nominal rating..
The State of charge needing to be high for stop start makes sense. Pointless to start using a battery to continually start a car during a journey if its charge is already low.
As an electrical guy and spent a lot of time in the battery/charging/UPS/Rectifier industry......I am dead against Stop Start but have it on a new Mazda which has to constantly be turned off at the start of each journey. The Stingers in Australia do not have Stop/Start. Even the latest My23. Mine don't and if they had I wouldn't have bought them.
Consider the failure mechanism for lead acid batteries. Most go though sudden death. What this means is....From Day 1 the positive plate starts corroding. It does this with charge current. Over those 4 or 5 years of life and remembering the lead plates in car batteries are wafer thin. This is to facilitate getting the current off the plates quickly as in feeding hundreds of amps to the starter motor. But they also corrode and after about 5 years one breaks off.
Usually this happens on the last start. So you start the car. A plate then breaks with that high current flowing through its narrowest point, but you drive away because the alternator is now doing the work. Your next start there is either "nothing" or you might have 5 cells left if the sixth is shorted with a broken plate so, a bit over 10 volts. So you have a low cranking voltage.
Now, if this deterioration happens over 5 years of two starts a day on average (a bit more I know)....you start to go to work. You start to come home. Each time the battery recharges, each time the positive plate corrodes a little more.
Now do this 20 times a day in city traffic. Start, recharge, start, recharge, start, recharge, corrode, corrode, corrode, corrode.
I don't want to be in the car in the outside lane of 80kmh with the engine off waiting for a green light and at the last set of lights that plate broke off. My car does not start and I am dead.
I have been in DC power for decades and along with my Electrical engineer colleagues......we have not bought electric cars or solar panels yet and have worked in battery and charging systems, designing, and implementing them for decades. The cost of replacing a Tesla 3 battery is around $17,000. The cost of replacing your solar and battery system is the same again. We will wait and see what happens with batteries with all of these new applications. It's not so much the capital cost. It's the reliability and replacement.
Why not? You bought the Mazda with ISG. I just turn that OFF each time I get in, first thing after starting.
78% is such a specific SoC that I wonder if it came from some calculation/battery aging curve, or if it's a translation from some fixed value like 12.4v.
At any rate, under the charging system page on kstinger.com, it lists standard voltage as 12.5-12.9v at 68deg F. Which still puts the 12.3-12.4 I've seen on the low side, but it's also been 25-40 out and probably under 50 in my garage. Maybe that'll change in the summer.
Why not? You bought the Mazda with ISG (Idle Stop and Go). I just turn that OFF each time I get in, first thing after starting.
A Mazda CX3 S Touring was bought because it was needed.. It was the best of what was available.
It ensured I did not want Stop/Go in the next car which, was bought a few months later.
You can turn it off all you want.
Stop/Go is a nonsense.
Each time it switches off to save fuel
Each time it restarts it puts more load on the alternator to recharge what was removed from the battery.
It's a transfer of energy from exploding fuel to electrical energy to recharge a battery. You get nothing for free and you save NOTHING. But you do get to charge your battery more often which is the failure mechanism. Corrosion of the positive plate during charge. The bane of all batteries.
Car manufacturers have little understanding of batteries. They rely on battery manufacturers and don't want to know the intricacies like most people so they don't pass it on.
The only effective way of determining a battery's capacity is to discharge it according to its rating.
Car battery manufacturers have provided simple tests like doing a short discharge. This says that the battery will work for this amount of time. A battery that looks good for 1 minute can be terrible over 30 minutes or 10 hours. A battery that looks average can be reliable and consistent over its entire discharge. Measuring the voltage while standing really tells you little.
I had the luxury of working for the largest battery manufacturers calculating and sizing batteries from discharge tables, supplying detailed technical advice and tendering large scale supply contracts and winning millions of dollars worth of business.
Lead acid batteries perform the same whether they are on oil platforms, in power stations, running cells towers or starting cars. Rarely is charge voltage if ever used to determine the state of charge. It's done through a variety of monitoring from discharge current, to end voltage, to recharge current and other means.
Because there is nothing else available for a car battery, suppliers use a very rudimentary approach of 12.1 V is charged and 11.9 isn't. I have old batteries in the garage and I can charge them up and provide a healthy float voltage. But when I come to discharge them they're stuffed as expected.
Lead acid batteries perform the same whether they are on oil platforms, in power stations, in cell phone towers or starting cars. Rarely is charge voltage if ever used to determine the state of charge. It's done through a variety of monitoring from discharge current, to end voltage, to recharge current and other means.
FYI:
Mazda stop and go does not use the starter:
"While conventional idling stop systems rely on a starter motor to restart the engine, Mazda's i-stop restarts the engine through combustion; fuel is directly injected into a cylinder while the engine is stopped and ignited to generate downward piston force."
FYI:
Ha ha ha
There you go
Still a dumb idea.
1. Aircon compressor no longer working
2. Fan still running inside
3. Entertainment system still running
4. Headlights, tail lights. turn lights (LEDS)
5. Vehicle systems still powered up.
All providing unnecessary drain on battery that should be powered by the alternator.
There are lights here that could be red for 10 minutes that involve multiple roads and a level crossing and a fire station.
I know. I will start my car...........
....and for those of you that are getting a little offended.
We're pretty laid back.
It's all good is a common saying with a couple of words thrown in. Everyone gets it.
The F word is on the six o'clock news. We aren't precious here.
Want to throw in a narky comment? No problem. Expect 100 back or don't do it.
That's how it works.
Highly doubt that the battery & starter motor are not looped somewhere in the Mazda stop/start system.
Looped?
The starter isn't used at all for the Mazda I-stop system.
The battery is certainly used, to power everything while the engine is off.
For our Stingers, just having the ignition on draws over 10amps.
LED Headlamps add another ~6A
I had a good post about current draw with engine off here
Ha ha ha
There you go
Still a dumb idea.
Re: Mazda not using the starter. I just mentioned it an FYI thing, nothing more.
I'm with you. I don't like start/stop systems of any kind either. First thing I do after I start my car is turn it off.
I feel the same way about cylinder deactivation systems, but that's another topic.
I made a VERY home made timer switch to deactivate the ISG feature automatically every drive cycle & activate auto hold.
Been using this for over a year now, works well for me.
if you click, and scroll, there's a whole heap of pics there showing hoe very home made it is.
All good guys. I apologise for my expertise on batteries and my ignorance on stop start. I should have researched this further.
......coasting up to a Stop sign I think wouldn't be a way to kick this thing into working. Long straight drives with no-one around would be preferable.
I mean, thats the best time. as soon as your foot comes completely off the gas for about 1 second, the system goes into "coasting mode" until you touch the gas, brake, or the vehicle slows down to 35mph. so if a toll plaza, stoplight, stop sign, right turn, anything of that nature is coming up in say a Qaurter mile ahead, just coast.
UPDATE:
I went into the settings of my car and turned coasting mode off, turned car off, then back on, went back into settings and turned coasting mode back on. started engaging about 3 miles/5 minutes from my house for the rest of the drive. next day, it didnt engage. havent driven it since. weather has been shit.
Here’s what I experienced a few days ago. 500 km trip. First 200 km, no coasting was possible. Included hills, straightaways, the works. The next 100 km, it would coast! The last 200 km, no coasting. Stopping only for bathroom/rest breaks. 2022 Elite, weather @18 degrees C. The battery should have been fully charged for most if the trip. No idea what’s going on there…
I stopped paying attention to my state of charge since the car starts up every time without issue. I'm almost always in Smart mode, and while Coasting seems to activate at different intervals (sometimes within a couple miles of home, sometimes it seems to take 20+ minutes of driving), it works pretty much every drive.
It's also a lot warmer out, so maybe the battery just naturally sits a few hundred mV higher, maybe the car is charging it more readily, or maybe something else entirely.
One other factor that will kick you out of Coasting: activating your turn signal. So that polite signal on a sweeping hill a half mile before your turn will cost you.
Thanks.. I haven’t noticed the turn signal effect. I never use Smart mode, maybe I’ll give that a try for a few weeks.
I don't know that the logic or threshold for Coasting would be any different in Smart mode vs. Eco, other than the fact that you have to be in "Smart Eco" (green logo, vs. white or red from driving more aggressively).
I have noticed that while I can stay in Smart Eco pretty easily driving around town, long hills will almost always push me into white/Comfort. Even if I'm very light on the throttle, eventually it'll downshift which flips it to Comfort (although it'll flip back to green/Eco very quickly).
The thing that I forgot to include in my prior reply to you was a suggestion to put a charger on your car to top off the battery. Even though your trip was very long, since our cars use some smart charging logic that selectively activates the alternator, it's possible you just never reached a high enough state of charge for Coasting to activate. When I noticed my battery was on the low side, and topped it off, Coasting came right back.
Much appreciated! I’ll try that. I have the Noco Genius 10, which is super easy to use and tops the battery off very gently.
