The new update broke the ability for my Carlink 3.0 adapter to work. Anyone else have this issue? I’ve tried multiple cables and my Carlink 3.0 adapter from my other car. Worked before, now it doesn’t
I actually had the May update break mine and I’ve been trying to fix it since then. Carlink has suggested several things, but it looks like this might work:
Please kindly download the latest firmware in the linkto your USB drive, then try the method below:
Link: U2W_AUTOKIT_Update.img
Please notice that the file name was renamed(the correct filename should be without (1)).
1, prepare a 32G or less U disk, and right click on the U disk, formatted as FAT32 format (4/8/16/32GB)
2, the img format firmware into the U disk (firmware name can not be modified, keep the name in the zip package)
3, find a charger plug to power up the product, and then insert the U disk into the box USB port to upgrade (do not upgrade in the car)
4, upgrade with red and green lights flashing, do not power off, wait until the bright red light or blue light on, and then wait 3 minutes to unplug.
If the USB flash drive meets the size, format, but the LED does not appear flashing phenomenon, please replace a USB flash drive
When you have successfully freshed your firmware, please plug the dongle into the wall charger or plug it in to the car,
once the red light is on,
connect the dongle's wifi with your phone , then input 192.168.50.2 in your phone browser to
log in the backend. Then check for update.
