I just got back from for a run with the stage 1 tune, see attached. I will try get out in the morning and do a run as you have suggested and post the log on the stock ECU.well for one you hit 1.7 bar in one of the pulls which is 25 psi (not good) and you also have less than 6 deg of ign timing which is WAY less than stock.... do me a favor... flash back to stock and do a pull starting in 2nd gear at 25 mph floor it and shift at 5900 rpm every gear till you hit 4th gear and send the log here
The stage 1 felt fine with none of the issues the stage 2 has, The car drove fine and WOT felt good. Something is very wrong with the stage 2 tune and seems to getting worse with each revision. I am honestly a little nervous to try another revision of the stage 2 tune.
