G70LEbyAdoom
1000 Posts Club!
- Apr 25, 2021
Yes, All updates to the tune that come out will be free, at least so far.If you buy a tune such as stage 2, do you get updates for free (or reduced cost) if they come out?
And good luck at the dyno! Please post the results.
Unfortunately, There seems to be some issues with my tune and the dyno runs didn't go as well as I hoped. Nathan and I are going to hop on a call to try and get to the bottom of the issues next week when he is back from vacation. I have tried several versions of the Stage 2 Tune and they are all currently having the same issues. I am also fairly certain that between myself, @AWDGT2 (Who doesn't have the issues, which points me in a good direction for what may be causing them based off of the features in his tune VS mine) and @Yves998 (who does have the same issue as I do, but does not have HFC's) it leads me to believe that I have a pretty good idea of what the issue might be. I have tried
Stage 2 High Octane +LC
Stage 2 Methanol (Includes LC)
Stage 1 TCU LC
Custom Stage 0 TCU+LC
and have mixed and matched them in every possible combo I could think of trying. If Memory serves, All of @Yves998 tunes have had the custom LC in them as well. @AWDGT2's Tunes, DO NOT have the custom LC in them, and his car is running fine. That makes me believe that something with the custom LC Maps is causing the issues. I wont be able to test this theory until Nathan gets back however.
Even more evidence that pushes me towards this theory, is that when I got my tune from them originally, I was seeing amazing stability in the entire run, from 0-140mph+
Then, I flashed the Stage 0 custom TCU tune, which is the OEM TCU tune, but it was changed to allow the custom LC to work. I tried it once, and wow. I was blown away. I launched on 5-7lbs of boost at 2600-2700rpm and did 0-60 in 3.4 seconds according to my JB4s logs, so realistically probably even quicker than that.
After that, I flashed the stage 1 TCU tune with LC and everything started going down hill. So at this point, I am fairly convinced that is the cause.
So, you can try any of the tunes you want, and if you have issues, they will be fixed, but for now I would only recommend the normal Stage 2 High Octane, or the Back end Flash, as I do not believe that either of those tunes have the custom LC in them.
For reference, I have a 2018 GT2, @AWDGT2 has a 2019 GT2, and @Yves998 has a 2022 GT2/Limited, So it doesn't seem to be exclusive to the newer cars which have the extra safeties built in.
