Alright. I need some help sorting out this information. And I'm apparently too new to post images or links, so sorry...
Issue:  The Valvoline 75W-90 causes popping and grinding where there was none before.
@escblads reports he's had success with the Valvoline plus a bottle of Trans-X Posi-Trac LSD additive.
Some other oils mentioned are Redline GL-5 75W-85, Royal Purple 75W-90 and Amsoil 75W-90. Neither of these users mentioned any noises but I don't know if we've had any long-term updates on that.
A technical service bulletin from KIA mentions the "abnormal rear differential noise of rrrrrrr" (lol) and specifies the oil be replaced with "SK HK JL Syn LSD Gear Oil 75W85
PLUS" with a part number of 02100-00121. This oil is supposed to have "friction modifiers" in it to reduce noise. The remarks are that old oil is 3.5% friction modifiers and the new oil is 7%.
Googling this part number gets you a blue bottle with a black label which has the "PLUS" (along with "GL-5" prominently on the label. But there's apparently no way to buy this oil outside of South Korea.
I have seen an "equivalent North American" part number of UM017 CH126. Googling that gets you a distinctly different bottle, black with a gray label, that does mention the friction modifiers on the back but doesn't have a "PLUS" on the front.  I suspect this might be the previous oil that KIA no longer recommends?
What's the recommendation here:
 - Keep the Valvoline and try the additive?
 - Swap it out for the Royal Purple or Redline?
 - Get the UM017 CH126 from a dealer?
 - Option 4...?
