Seems like it's for the LSD, and the AWD stingers don't have a LSD. Maybe the GTS.Is this problem specifically only for Rwd Stingers?
Seems like it's for the LSD (Limited Slip Differential), and the AWD stingers don't have a LSD (Limited Slip Differential). Maybe the GTS.
Wait how come you guys get LSD with AWD? That's not fair. My only option was RWD or GTS.The GT2 AWD (called the "GT Limited" in Canada) has the LSD (Limited Slip Differential) rear.
Mine has the shudder when its cold and you do a tight turn....reminds me of my old 70 Buick GS that had a 12 bolt posi LOL. FWIW, I just call it the "The posi hop". Regardless I'll mention it when I go in for my first service. Funny though, mine is 2020, you would think they would have sorted this out by now.
Doesn't bother me much as I grew up with Muscle cars that always had LSD (Limited Slip Differential)'s. I suspect all they add is a friction modifier into the diff to help the clutch packs slip a little easier, allowing the inside axel to slip (I did this for my Mustang).
We get UVO, dynamic headlights and dynamic bolsters as well....LOLWait how come you guys get LSD (Limited Slip Differential) with AWD? That's not fair. My only option was RWD or GTS.
Best to get it done now in case it worsens.I have just passed 13000km with my car and this morning I noticed a noise from the diff as I backed out of the driveway and turned into the street, came here to investigate and found this thread, I’ll keep an ear on it and get the oil changed next service
What's your build date?I have just passed 13000km with my car and this morning I noticed a noise from the diff as I backed out of the driveway and turned into the street, came here to investigate and found this thread, I’ll keep an ear on it and get the oil changed next service
Funnily enough I called Kia service department & the guy pretty much said since there's no recall on your car they will not do anything.Best to get it done now in case it worsens.
Unaware of the TSB! I'd be looking for another dealer.Funnily enough I called Kia service department & the guy pretty much said since there's no recall on your car they will not do anything.
I told him preventive maintenance surely is better than risking potential damage from acting too late.
The TSB is quite vague in that it doesn't specify certain VIN/build date it applies to or whether it's applicable to all.Unaware of the TSB! I'd be looking for another dealer.
I read it as "All" fitted with LSD.The TSB is quite vague in that it doesn't specify certain VIN/build date it applies to or whether it's applicable to all.
Surely Kia would keep records of what fluids are being used at the production lines...?
I'm guessing the friction modified implies 'full synthetic' meaning it performs better and more importantly lasts much longer.
The regular one may function well until a certain mileage - this is then wear n tear will start to occur.
I'm disappointed by the lack of competence of the Kia dealers.
The Stinger is truly excellent & a product of exceptional quality, shame Kia's general service is not up to par.
So your implying that Stingers being built today are still being filled with the incorrect fluid?I read it as "All" fitted with LSD (Limited Slip Differential).
Here's what you need....
I can't comment on current build dates.So your implying that Stingers being built today are still being filled with the incorrect fluid?
How long did it take Kia to complete the change for you?
I would assume that once the TSB is released this would include all Stingers shipped/sold prior to the TSB.So your implying that Stingers being built today are still being filled with the incorrect fluid?
Mine is Dec 2018 build dateI would assume that once the TSB is released this would include all Stingers shipped/sold prior to the TSB.
Once Kia realises there is an issue such as this any vehicles manufactured after the TSB release would have this issue addressed in the factory prior to assembly.
Mine is Oct 2017 build date & diff oil was replaced under warranty 18/10/18.Mine is Dec 2018 build date
