StingertimeNC
1000 Posts Club!
Ok gang, a couple of you wanted to hear about the BMS intercooler.  Got a log today, but did not do any Dragy testing yet.  I do believe this is helping with IAT's.  At the start of the pull my IAT was 107 degrees at 37 MPH, and by the time I reached 108 MPH, it had dropped to 93 degrees.  Ambient temp was about 86 degrees.  After I let up, the temps continue to drop down to 84.  This is typically what I experience with the WMI- as soon as you stop pulling, the temps really drop down.
During a recent 0-130mph run (log attached, ambient temp around 82,) the IAT's only go from 98 to 91 degrees, but go back up to 96 degrees by the time I finish the run to 130mph, and that's with meth flowing great. Terry reviewed this earlier log and said "Looks pretty normal to me. IAT isn't much of an indicator of meth flow, you'd want to focus on fuel trims and knock count. Both seem pretty low so I'd assume meth is flowing properly here." I'll work on some dragy testing next. I think the Intercooler is well built and sturdy. Easy install, except it took my a while to figure out the clamp thingy on the driver side, which you have to re-use, so be careful with that. The intercooler is huge compared to stock, and the price is right! Hope that helps!
