Lozic TCU + JB4 report
Today I got my TCU with pressure 2, torque control off and -5% in shift rpm and here is the first report, more will follow:
Daily driving:
Very little difference from stock, works good in every run mode. Can notice a slight hard downshift to gear 1 when you let off the gas completely. I think also that TCU+ECU will relearn a bit. But it doesn’t matters, it’s the higher pressure of course and does not bother anyone I think.
Launch in Comfort like a stock launch:
Feels like stock, I didn’t notice 5 psi as Lozic said. I did wait until turbin try to engage so time would have been enough before let go. I will test more.
Wishes: That it would be possible to launch like stock but with some positive boost like 5 Psi before turbin engage. Maybe a bit lower Rpm could help if that is possible from the TCU unit.
Launch in Sport and Sport+ with antispinn and antislip off:
First time I did wait a second to much, probably also to much pedal and boost will go up fast. I did let go and all 4 spun heavy. But I can see in Dragy that time from zero is lower so there is a advantage to could launch like that. Tried a few times more and learn, no more than 2.500 Rpm and then a fast release of brakes. Recommendations is that go slow on pedal so you have time to notice boost and also have time to let brake off.
Wishes: I would like to have some Rpm limit here and also some boost limit in first gear to be safe and not brake anything. I tried to adjust in JB4 settings Map 5 with “max Boost 1st gear” and it gave a bit safety but then when launch is done you have limit boost, I did put in 5 and boost did stay at like 15 after launch compared to 20-21. I tried 10 also and the launch itself is better but to low after launch. It can be something to test for you JB4 guys. I also did test Map 6 and tried to have only stock boost up to 3.000 Rpm by putting zero in “Map 6 Boost” first 4 columns but it didn’t work good. I will test it more as rain did come. If JB4 got a boostcurve/limit per Rpm for 1st gear it is solved.
Actually I have not got Map 6 to be faster than Map 5 at any time. Map 5 is hard coded and work great, even there I don’t think Map 6 can do more for us with all bolt ons. For guys that don’t have all bolt ons I think Map 3 is the fastest one for them and next mod should be TCU if they already have JB4.
Auto shifting at WOT:
Yes, its more firm and faster, no feel like slip anymore. Pressure 2 seems to be a good choice with us with all bolt ons. No need for more as I don’t think shifting would/could be more fast. I can also see in JB4 log that boost don’t drops more than a few Psi when shifting.
With -5% shifting points it shifts at 6.000 Rpm and it helps performance. It will only shift there in Sport and Sport+, in other driving modes it shifts higher.
Wishes: That Lozic put text in their Excel order sheet what they recommend as it can vary with
mods and other things. More stock tuning or less bolt ons would benefit with shifts at less Rpm, maybe like 5.700-800. It also then will be easier to make fuel be less limit.
Summary:
Lozic is worth the money if it stays at $950 and works well if… you have the right settings to your
mods, how to use the car and goals.
- I will say that pressure 2 will be enough for 95% at this forum.
- Choose shifting points after your mods
- If you already have a JB4 go for TCU and also if you plan to do more mods as it can be adjusted easy. Also a good thing is to have the possibility to change map at phone or wiper with JB4.
- There will be minor difference in performance between JB4 and Lozic Ecu, for most of us
- TCU do good for what any tune you have
What next:
I will try out Comfort and Sport launch and share my findings with you. I also hope if Lozic can develop the launch more and that also JB4 users in future can adjust launch rpm and boost by 1st gear. Then its complete. Would be a very good thing.
No, I am not favoring any vendor, just share my experience as I am old... 63, and also hope that Lozic and Burger read this!
3.58 (0-62 mph) with 1 ft roll out is ok with very light launch. I hope I can improve this and then also go for quarter mile. I hope for 11.5
