Ty Davis
Just a little update here, now that I’ve had the car a few months and have added some miles.
Comfort mode does cut throttle now when wheelspin is detected.
If I am turning onto a street from a stop sign, I will often get a distinct pause in acceleration when the inside wheel slips a bit. Here it seems that the traction control has become more strict. Or perhaps it’s due to having aftermarket suspension that changed the grip ratio front to rear.
I did find that Comfort, Sport, and Custom (with Steering/suspension set to sport and Engine to Comfort) all have different levels of ESC control.
I assumed because I had the engine set to Comfort in customer mode, the ESC was in its most strict setting.
This misconception was reinforced by the fact that the ESC did in fact get more lenient in Sport.
I always use Custom mode, sometimes Sport, but rarely comfort.
But as of today, Comfort mode ESC can be quite restrictive and I no longer would be hesitant to turn a young driver loose with the basic ESC setting.
Custom mode does do away with some of the fuel cut when wheelspin is sensed.
It allows a smidge of tail angle too if you get into oversteer.
Sport mode ESC is truly sporty. I never need to turn of my ESC or TCS fully, as Sport mode stays out of the way nicely.
