Ty Davis
By comparison, notice how the BMW system never really allows the vehicle to exceed the tires available grip. This is my experience with the ABS/Traction Control/Stability Control on my last couple of Bimmers. No matter how hard you drove it, the computers seem to hold the car at peak available Traction. If you hit a slick spot, or accelerated, or cornered, or braked too hard, the computers would kick in. But even when they were actively stabilizing the car, there was never a feeling lost traction or lost momentum. It was effective but not intrusive. That being said, I have noticed that BMW ESC/DSC is very relaxed on controlling understeer. That system waits for you to brake and then uses the Corner Brake Control to rotate the car, eliminating the understeer and causing the car to turn.
Back to the Stinger... There’s certainly room for improvement on the next generation of Stinger, with owners here reporting it’s too intrusive and others finding it very relaxed.
I might may find an empty parking lot and demonstrate just how relaxed mine is at low speed turns at neighborhood/city speeds. The car can literally do a 360 spin with the system on.
). URL - below. His impressions were much the same as mine after I drove it. And, he had good comments about the drive-ability, but having to have "your wits about you" especially in Sport mode. Very salient to this discussion. (I just spun it up again, see starting about 12:20).
it is right next to the right indicator light, togther with the tracton off Symbol. so if you turn ESC off manually you will see it
