Drag/Acceleration The Official 1/4 mile track thread.
Hey, Question, for those RWD guys, with JB4 and meth, what are you doing to help control wheel spin? Who’s using the reduce boost by gear on the JB4 and if you are using that feature, what are
Your settings? I see Terry suggested to reduce by 5 in 1st gear, and 1 in second gear. Running map 7, 93 octane, oem tires on 19 inch rims that are 8 lbs lighter on the rear. Thanks for any suggestions.
I didn't do boost by gear when I went to the track and I should have. I did 3 runs, all on Map3. My 60 fts were horrendous: 2.1-2.3. Tires were cold, didn't do a burnout but still managed a 12.4 1/4. I haven't tried the e-brake launch but heard that helps build boost on launch and has helped the AWD guys. For us RWD, it may worsen out lives lol
Next time I go I'll drop first gear by 5 or 6 and see what that does. The track was prepped pretty well but I've gotten 2.0 60ft times on the street so I'm not sure what that is about. Looking into a wider/stickier tire as well. It's not my daily driver so I can go pretty aggressive.
Regardless, boost by gear will help you at the track. Dropping 5 or 6 will put you close to stock psi when launching. I haven't touched 2nd gear boost reduction because I hook as soon as it shifts into second.
Get drag radials or reduce boost in 2nd gear 3 and 1st gear 1 and adjust from there as needed.
AWD, send all the boost..... but back to basics first. Get drag radials or really good sticky tires.
As soon as the rears wear out, PS4S will be going on. Still messing with the boost reduction. Haven't had much time to play with it. Thanks for the thoughts.
Eager to see if some of you guys in the top 1/4 mile list will purchase a TCU tune and show how much it can improve. Some of you only need a few tens to be in the 10s and with maybe with stronger launch and faster shifts you will bring the Stinger there!
I believe the stock transmission programming and launch mode is a very important limitation factor for the Stinger. Launch can be by passed with the snip but not a perfect solution either.
1/4 Drag strip Top 20 times (Official Track List)
1/4 mile time, speed, 1/8 mile time, speed, 60 foot
Congratulation to Jaque for making #12 on the list ***There are NO 12 sec stingers left!!!
1. 11.160 @ 123.72 @AWDGT2, 7.176 @98.43 1.637
Jb4, MAP 6, Agency Intakes, Agency FMIC, WMI, MBRP exhaust, BMS snip, 100 Octane
2. 11.180 @124.20, @Kato_the_kia_stinger 7.220 @97.01, 1.687
GT AWD, JB4 Map6, JT intake, WMI, GT9 Catback, Ark Mids, Wagner FMIC, MS103, BMS brake snip
3. 11.250 @122.52, @gingfreaccs , 7.249 @97.36, 1.610
Lap3 ECU, Lap3 Protuner, WMI, Lap3 Downpipe, AEM intakes, Stock FMIC Stock Mid pipes, MS109
4. 11.281 @ 124.9, Yaroslav Ossipov, 1.742 (Russian track no slip, just photo of board )
GT2 AWD, Motec, Pure turbos, catless, Perin FMIC, K&N intake, Vibrant exhaust, 100 octane, Motec launch control
5. 11.296 @ 123.91, @ScottyCole, 7.306 @97.96, 1.729
GT1 AWD, Tork Stage 2 ECU tune, K&N Intakes, Ark Mid, Borla, Catback, UP FMIC, WMI, BMS brake snip, 93 E20 octane
6. 11.466 @ 122.7, @Tonkabob, 7.450 @ 97.33, 1.83
GT2 AWD, Tork Stage2 ECU tune, WMI JB4 controlled, Ark catback, JT intake, UP FMIC, E30, Launch control
7. 11.488 @ 120.27, @madhouse 7.378 @94.99, 1.64
GT AWD, Jb4, Injen intakes, Borla exhaust, secondary bypass(dump valves) Bigger big mouth intakes, fmic, WMI, BMS brake snip, E30+93
8. 11.548 @ 122.05, @Crewdawg130, 7.49 @95.66, 1.719
GT2 RWD, Hybrid turbo, JB4, WMI, FFP intakes, Ultimate HFC primary and secondary, FMIC, Drag radials, BMS brake snip.
9. 11.575 @ 119.91 Angel David, 7.45@ 94.17, 1.584
RWD, Lap3 Pro, WMI, DP, MP, FMIC, intake, Drag radials, BMS brake snip.
10. 11.600 @122.7, @TorkMe, 7.580 @97.19, 1.931
GT RWD, Tork ECU tune, Tork Intake, muffler delete, no cats, FMIC. 104 octane
11. 11.618 @121.30 @Rakker , 7.553 @ 97.96, 1.876
RWD, JB4, HKS plugs, JA Air scoops, Borla Exhaust, BMS FMIC, BMS snip, BMS diff brace
12. 11.692 @icefrost Jacque Lavige 1/8? @ ? 1.623
AWD, Lap3, K&N intakes, BMS Intercooler, Snorkels, Borla exhaust, HKS, 101 Octane
13. 11.727 @ 115.57 @Snowman70741 7.474 @91.46 1.444
JB4, BMS intake, BMS Intercooler, Ark Midpipes, BMS Diff Brace, BMS snip, E30
14. 11.764 @116.79, @Angel, 7.542@92.18, 1.608
AWD, JB4 Map 5, AP Intakes, SSR Downpipes, SSR Muffler Deletes, Tork OCC, VT snorkel, BMS brake snip
15. 11.821 @119.47 @Mickey13, 7.615 @92.78, 1.736
Gt1 awd dyno comp ecu, jb4, meth, agency cai fmic, borla and ark exhaust, denso plugs
16. 11.829 @116.80. @John_P 7.614 @92.20, 1.677
AWD Mid/Down pipes, ARC Grip catback, Wagner Intercooler, HKS BOVs, Catch Cans, Ingen Intakes, jb4 Map 7, WMI, E-30
17. 11.862@ 117.36, Fernando Perez 7.670 @ 93.32, 1.719
AWD GT2, Tork back end, Jb4, WMI, Agency FMIC, K&N Intake, catless, custom catback, brake snip
18. 11.911 @ 117.75, Jose Martinez, 7.718 @ 92.98, 1.787
GT2 AWD, Lap3 V2, WMI, Wagner FMIC, NGT primary and secondary, JunBL catback, Brake Snip, 91+E85
19. 11.9332 @ 116.62, Michael Locke, 7.702@ 91.61, 1.733
GT2 AWD, Lap3 Pro V2, WMI, Ingen intakes, Ark mid, BMS brake snip
20. 11.933 @ 116.82, @Hyperjetta 7.708 @ 92.01, 1.70 ish
GT AWD, JB4 Map3, DIY intake, BMS brake snip, E30
12. 11.692 @ ? Jacque Lavige 1/8? @ ? 1.623
RWD, Lap3, Intercooler, Scoops, exhaust
In all fairness there are some 12 second Stingers left but no one pays any attention to them anymore.
Are we finally going to see a 10 second Stinger this month before it starts to get too hot?
11.853 @ 116.91 @MarcBrassard , 7.624 @ 91.5, 1.728
GT2 AWD JB4 map 4, E30, K&N intakes, JA snorkels, MBRP exhaust, BMS intercooler, BMS brake snip.
Pont Rouge Dragway in Quebec Canada.
1/4 Drag strip Top 20 times as of 6 May 2021 (Official Track List)
Congratulation to @TheDangOne and @Frenchy_418 for making list! It's getting fast, only one 11.9" stinger left on the list.
1. 11.160 @ 123.72 @AWDGT2, 7.176 @98.43 1.637 (20 March 21)
2. 11.180 @124.20, @Kato_the_kia_stinger 7.220 @97.01, 1.687 (21 March 21)
4. 11.272 @124.49, @TheDangOne , 7.297 @97.38 1.646 (6 May 21)
AWD,
5. 11.281 @ 124.9, Yaroslav Ossipov, 1.742 (Russian track no slip, just photo of board )
6. 11.296 @ 123.91, @ScottyCole, 7.306 @97.96, 1.729
7. 11.466 @ 122.7, @Tonkabob, 7.450 @ 97.33, 1.83
8. 11.488 @ 120.27, @madhouse 7.378 @94.99, 1.64
9. 11.548 @ 122.05, @Crewdawg130, 7.49 @95.66, 1.719
10. 11.575 @ 119.91 Angel David, 7.45@ 94.17, 1.584
11. 11.600 @122.7, @TorkMe, 7.580 @97.19, 1.931
12. 11.618 @121.30 @Rakker , 7.553 @ 97.96, 1.876 (6 May 21)
13. 11.692 @icefrost Jacque Lavige 1/8? @ ? 1.623 (4 May 21)
14. 11.727 @ 115.57 @Snowman70741 7.474 @91.46 1.444
15. 11.764 @116.79, @Angel, 7.542@92.18, 1.608
16. 11.821 @119.47 @Mickey13, 7.615 @92.78, 1.736
17. 11.829 @116.80. @John_P 7.614 @92.20, 1.677
18. 11.853 @ 116.91 @Frenchy_418 7.624 @91.50, 1.728
19. 11.862@ 117.36, Fernando Perez 7.670 @ 93.32, 1.719
20. 11.911 @ 117.75, Jose Martinez, 7.718 @ 92.98, 1.787
Did every one of the top 20 use some form of brake boost launch? Numbers 11 and 12 are the only ones that look like they might be possible without a boost assisted launch.
However, both of those times are really excellent RWD launches.
It really appears that brake boosting is a requirement to go fast now.
#12 is listed as having the snip. I think the only guys that won't do the snip are the hard core Tork platforms. Because it's a BMS initiated find, I believe it's a pride thing. They are few though and most still do it.
Yeah the only way people are running 60fts of 1.5s or 1.6s easily is from the BMS brake switch.
The Lap3 full ECU & piggyback combo is the only other one that makes 1.6s possible. Even Torks top Stingers with boosted launch & huge boost in 1st gear does 1.73-1.83s. Think they also had the advantages of boosted & quicker shifts the Tork backend provides but not sure.
1/4 Drag strip Top 20 times as of 9 May 2021 (Official Track List)
1. 11.139 @ 122.99 @AWDGT2, 7.136 @98.21 1.568 (8 May 21)
Jb4, MAP 6, Agency Intakes, Agency FMIC, WMI, MBRP exhaust, BMS snip, Renagade fuel.
AWD,
8.34@88mph 1/8mile
Think the torque converter kills us AWD types, it dont truly pull til bout 15-20mph...no im not doing the brake snip even if it means 60' is better haha
8.34@88mph 1/8mile
Nah, it's torque limiters in the ECU and TCU
