Hello guys,
I live in Seoul and I have been driving the stinger for over 7 months now.
Rattles have bothered me a lot for few months until I fixed them myself.
There are two types of rattles I have found annoying in this car.(otherwise very satisfied!)
The first type is the tailgate rattle.
It's only recently that Kia started fixing the cars for rattles with the new side stoppers.
Before, they would just test drive the car and adjust the height of the adjustable stoppers. (the ones on the door)
It does help a bit, but the rattles will not go away.
Interestingly, you guys came out with the same solutions as people in korean forums.
For the tailgate rattle, here is my fix using multiple layers of anti-noise(?) tape.
But now that they got replacements for the stoppers, don't bother and just get the new stoppers.
The second type of rattle is a little noise coming from the windows.
The reason seems to be the door sealings rubber not being soft enough.
Here, some owners have had Kia replace the door sealings, but it is not a standard operation as the cause is not obvious,
and you also have to duplicate the noises when test driving.
Having no time to argue with the Kia guys, I have found that one simple application of silicon spray did the job perfectly.
So if you ever get window rattles, try spraying a bit on the rubbers/plastics above each window (on the door side), and voila.
