[DIY] [Guide] Drive Mode Memory Module (prototype)
Wow! I guess a lot has changed since Eagle from Cadsoft was bought and went to a subscription model. I'll have to check out EasyEDA.
Sneak peak at some upcoming features! find the latest beta on the github
ps: this will be included on the newest version of the PCB soon as testing is done.
EDIT: Can you see the bug? It's already been fixed on github after I took this screenshot! hahaha
You’re writing the future state of auto hold over the eeprom value of the state for isg?
You’re writing the future state of auto hold over the eeprom value of the state for ISG (Idle Stop and Go)?
memFuture2Addr is the variable for the address in eeprom to be accessed. the error is "isg" on that line. it's supposed to be the variable "ahold"
Edit: like I said, it's been fixed in the github already ksdmmm github
Ok I sent these both into production in China. the "DIY" version will be much cheaper but will not come with wiring, taps, or components, and will not be pre-programmed. I'll be doing a guide on using it once they arrive, you can hook into the debug port with an SPI to USB and Serial to USB adapter card to install the bootloaders and programming.
The full version will come with everything including positaps wiring and all components pre-installed and be pre-programmed and has a built in Serial to USB chip for firmware updates.
Both support Drive mode memory, ISG memory, and Autohold memory as well as future integration (via the debug port) with later modules (I'm working on an ambient lighting control module that will have full RGB support and could be variable to drive mode)
Pricing will probably be somewhere in the $30 for the DIY and somewhere in the $90 range for the full version.
DIY (75mm x 50mm x ~10mm):
Full Version (40mm x 40mm x ~10mm):
Very nice! Thank you for doing this. I will be in for the full version.
Do you need a hand with this? I've done a lot of Arduino work, and my own PCB design, including full fabrication.
I've also done Bluetooth Low Energy and WiFi, so that could tie into a phone app for settings.
Also, if you use a 32u micro you don't need the USB bridge.
I’ve got the fabrication down. I considered wireless communication however it would increase production cost as well as R&D. I’m trying to keep this competitively priced.
This is true, I’m going to offer pre-programming service as-well, I have a website all setup for sale of these since multiple Facebook groups and forum members have shown interest, just waiting on approval to get vendor status
Now that I think about this, I have a GTS and drive around in Sport+ mode during good weather. It is enabled by holding down the traction control button for roughly 5 seconds. Any possibility that this can be added? I'd even go for using the output for Autohold to be used for the traction control button.
Thanks,
George
Thanks,
George
It is planned for a future version, however I need to hook up my scope because it's not a "normally high switch" like the other buttons interfaced. I've been working with a friend on a pro version of the ksdm with a ton of other features, but likely we won't have it ready until close to end of year.
EDIT: I also want to mention that the "DEBUG" port is an SPI header and there will be planned add-on modules along the way that interface with the CPU on the ksdm3, traction control, activation switch (to run a macro on the board such as "Joe's super cool track mode macro") ambient lighting control (have it red in sport mode, green in eco etc) and other stuff too. I have plans and I've been bringing in people with ideas
Great work. Being in Michigan, I am really looking for heated seats and steering wheel (to turn on with OEM remote start). I saw you said that may be planned for the future. If it is able to be done, any idea on timing? I wouldn't want to get one module and have to replace it in only a few months. Thanks a lot.
Thanks a bunch for doing the design work on this, I'm excited to try making my own.
I spent a little time this morning re-writing the software to be able to use interrupts or polling, but I haven't tested it on my car yet, so typos are likely.
A nano only has 2 interrupt capable pins, so polling would be eventually required for ISG (Idle Stop and Go) operation. Other chips like a teensy could use interrupts, but in a case like this, I think a tight polling loop is fine.
C:
#include <Arduino.h>
#include <EEPROM.h>
// how long we need to wait between changing modes automatically (in milliseconds)
#define OUTPUT_WAIT_TIME_MS 1000
// how long we need to hold the button down when changing modes automatically (in milliseconds)
#define OUTPUT_PULSE_TIME_MS 250
// how long it takes the car to start up (in milliseconds)
#define STARTUP_WAIT_TIME_MS 5000
// intput pins
#define CW_INPUT_PIN 2
#define CCW_INPUT_PIN 3
// output pins
#define CW_OUTPUT_PIN 5
#define CCW_OUTPUT_PIN 6
// enable debug messages
#define DEBUG
// debug print wrapper
#ifdef DEBUG
#define DEBUG_PRINT(x) Serial.println(x)
#else
#endif
#define INTERRUPTS
//#define POLLING
// memory address we store the mode in (not currently wear leveled, will handle ~100,000 mode changes)
int EEPROM_ADDRESS_MODE = 0;
// memory address we mark to signify first startup
int EEPROM_ADDRESS_INITIAL_SETUP = 1;
const byte MODE_FIRST = 0;
const byte MODE_SMART = 0;
const byte MODE_ECO = 1;
const byte MODE_COMFORT = 2;
const byte MODE_SPORT = 3;
const byte MODE_CUSTOM = 4;
const byte MODE_LAST = 4;
const byte MODE_IMPOSSIBLE = 255;
// global that stores current car mode
byte currentMode = MODE_IMPOSSIBLE;
// global that stores current target mode
byte targetMode = MODE_IMPOSSIBLE;
void update_eeprom(void)
  // only update eeprom if data is different (prevent eeprom wear)
  if (EEPROM.read(EEPROM_ADDRESS_MODE) != currentMode)
    EEPROM.write(EEPROM_ADDRESS_MODE, currentMode);
    DEBUG_PRINT("EEPROM Update");
    DEBUG_PRINT(currentMode);
// capture a cw physical knob turn
void knob_cw(void)
  currentMode -= 1;
  if (currentMode < MODE_FIRST)
    currentMode = MODE_FIRST;
// capture a ccw physical knob turn
void knob_ccw(void)
  currentMode += 1;
  if (currentMode > MODE_LAST)
    currentMode = MODE_LAST;
// simulate a clockwise turn of drive mode num times
void clockWise(int num)
  for (int i = 0; i < num; i++)
    digitalWrite(CW_OUTPUT_PIN, HIGH);
    delay(OUTPUT_PULSE_TIME_MS);
    digitalWrite(CW_OUTPUT_PIN, LOW);
    DEBUG_PRINT("Automated CW");
// simulate a counterclockwise turn of drive mode num times
void counterClockWise(int num)
    digitalWrite(CCW_OUTPUT_PIN, HIGH);
    digitalWrite(CCW_OUTPUT_PIN, LOW);
    DEBUG_PRINT("Automated CCW");
void setup()
  // must use pins 2 and 3 for interrupts on an nano
  pinMode(CW_INPUT_PIN, INPUT_PULLUP); // clockwise input
  pinMode(CCW_INPUT_PIN, INPUT_PULLUP); // counterclockwise input
  pinMode(CW_OUTPUT_PIN, OUTPUT); // clockwise output
  pinMode(CCW_OUTPUT_PIN, OUTPUT); // counterclockwise output
  // if this is the first use set the default drive mode, car is expected to be in comfort mode
  if (EEPROM.read(EEPROM_ADDRESS_INITIAL_SETUP) != 1)
    DEBUG_PRINT("First Boot");
    EEPROM.write(EEPROM_ADDRESS_MODE, MODE_COMFORT);
    EEPROM.write(EEPROM_ADDRESS_INITIAL_SETUP, 1); // mark initial setup as done
    targetMode = MODE_COMFORT;
  else
    DEBUG_PRINT("EEPROM Loaded");
    targetMode = EEPROM.read(EEPROM_ADDRESS_MODE);
    DEBUG_PRINT(targetMode);
    // car remembers eco and comfort settings
    if (targetMode == MODE_ECO || targetMode == MODE_COMFORT)
      currentMode = targetMode;
    else
      currentMode = MODE_COMFORT;
#ifdef DEBUG
  Serial.begin(115200);
#endif
  // wait for car to start up
  delay(STARTUP_WAIT_TIME_MS);
  // change the car mode if needed
  if (targetMode < currentMode)
    counterClockWise(currentMode - targetMode);
  if (targetMode > currentMode)
    clockWise(targetMode - currentMode);
#ifdef INTERRUPTS
  // watch for the mode to change
  attachInterrupt(digitalPinToInterrupt(CW_INPUT_PIN), knob_cw, FALLING);
  attachInterrupt(digitalPinToInterrupt(CCW_INPUT_PIN), knob_ccw, FALLING);
#endif
void loop()
#ifdef POLLING
  // poll cw
  static bool previous_cw = true;
  bool cw = digitalRead(CW_INPUT_PIN);
  if (cw == false && cw != previous_cw)
    knob_cw();
  previous_cw = cw;
  // poll ccw
  static bool previous_ccw = true;
  bool ccw = digitalRead(CCW_INPUT_PIN);
  if (ccw == false && ccw != previous_ccw)
    knob_cw();
  previous_ccw = ccw;
#endif
  update_eeprom();
So I got pretty deep into AVR programming and I like your thoughts on interrupts vs polling. I wrote some code for an extremely low power module (note: this code includes all my latest hardware updates including optocouplers and FRAM so it may seem different)
note: I edited the code changing all instances of 'isg' with 'gsi' because the forum annoyingly autoreplaces it.
C++:
#include <avr/sleep.h>
#include <EEPROM.h>
// Nominal input Values
#define NOM_PIN3 1
#define NOM_PIN4 1
#define NOM_PIN7 1
#define NOM_PIN9 0
// some arduinos have issues with pulling ground to some pins upon startup.
#define ERROR_OFFSET 1
// Set time to wait before outputing memory to vehicle in ms (recommended
// 2000-5000)
#define STARTUP_WAIT_TIME 4000
int memAddress = 0;
int memSetupAddr = 1;
int memgsiAddr = 2;
int memFuture2Addr = 3;
const byte SMARTMODE = 0;
const byte ECOMODE = 1;
const byte COMFORTMODE = 2;
const byte SPORTMODE = 3;
const byte CUSTOMMODE = 4;
byte currentMode;
bool ahold = false;
bool gsi = true;
byte memRead(int addr) {
  byte r;
#ifdef USE_FRAM
  nvRAM.readByte(addr, &r);
#else
  r = EEPROM.read(addr);
#endif
  return r;
void memSave(int addr, byte value) {
#ifdef USE_FRAM
  nvRAM.writeByte(addr, value);
#else
  EEPROM.write(addr, value);
#endif
void clockWise(int num) {
  for (int i = 0; i < num; i++) {
    digitalWrite(5, HIGH);
    delay(250);
    digitalWrite(5, LOW);
    delay(250);
void counterClockWise(int num) {
    digitalWrite(6, HIGH);
    delay(250);
    digitalWrite(6, LOW);
    delay(250);
ISR(PCINT2_vect){
  if (digitalRead(3) != NOM_PIN3){
    if (currentMode <= SMARTMODE) {
      currentMode = SMARTMODE;
    } else {
      currentMode--;
    memSave(memAddress, currentMode);
  if (digitalRead(4) != NOM_PIN4){
    if (currentMode >= CUSTOMMODE) {
      currentMode = CUSTOMMODE;
    } else {
      currentMode++;
  if (digitalRead(7) != NOM_PIN7){
    gsi = !gsi; // reverse the value from current.
    memSave(memgsiAddr, gsi);
ISR (PCINT0_vect)
  if (digitalRead(9) != NOM_PIN9){
    ahold = !ahold; // reverse the value from current.
    memSave(memFuture2Addr, ahold);
//############### Start point ############## //
void setup() {
  pinMode(3, INPUT_PULLUP); // clockwise input
  pinMode(4, INPUT_PULLUP); // counterclockwise input
  pinMode(5, OUTPUT);
  pinMode(6, OUTPUT);
  pinMode(7, INPUT_PULLUP); // gsi (Auto Start Stop) input
  pinMode(8, OUTPUT);
  pinMode(9, INPUT_PULLUP); // Auto Hold input
  pinMode(10, OUTPUT);
  if (memRead(memFuture2Addr)) {
    ahold = true; // enable Autohold
  if (!memRead(memgsiAddr)) {
    gsi = false; // disable gsi
  // If initial setup hasn't completed, set the default drive mode
  if (memRead(memSetupAddr) != 1) {
    // Write the default to permanent memory
    memSave(memAddress, COMFORTMODE);
    memSave(memSetupAddr, 1);
    currentMode = COMFORTMODE;
  } else {
    // Setup has completed read the current mode from permanent memory
    currentMode = memRead(memAddress);
  delay(STARTUP_WAIT_TIME);
  switch (currentMode) {
  case SPORTMODE:
    clockWise(1 - ERROR_OFFSET);
    break;
  case CUSTOMMODE:
    clockWise(2 - ERROR_OFFSET);
    break;
  case SMARTMODE:
    counterClockWise(2 + ERROR_OFFSET);
    break;
  case COMFORTMODE:
    counterClockWise(ERROR_OFFSET);
    break;
  case ECOMODE:
    break;
  default:
    break;
  if (ahold) {
    digitalWrite(10, HIGH);
    delay(250);
    digitalWrite(10, LOW);
  // if gsi is disabled in memory, send a signal. gsi is on by default.
  if (!gsi) {
    digitalWrite(8, HIGH);
    delay(250);
    digitalWrite(8, LOW);
  PCMSK2 |= bit (PCINT19);  // Attach pin 3
  PCMSK2 |= bit (PCINT20);  // Attach pin 4
  PCMSK2 |= bit (PCINT23);  // Attach pin 7
  PCMSK0 |= bit (PCINT1);   // Attach pin 9
  PCIFR  |= bit (PCIF0);    // Disable prior interrupts on PCINT0_vect
  PCICR  |= bit (PCIE0);    // Enable new interrupts on PCINT0_vect
  PCIFR |= bit (PCIF2);     // Disable prior interrupts on PCINT0_vect
  PCICR |= bit (PCIE2);     // Enable new interrupts on PCINT0_vect
void loop() {
  set_sleep_mode (SLEEP_MODE_PWR_DOWN);  // Put the CPU into low power sleep mode
  sleep_mode ();
If you're interested, here is the current hardware schematic and PCB layouts:
I'm developing a KSDMPRO module that will do a ton of stuff from auto-setting the parking brake (if you have electronic parking brake) to optionally disabling traction and stability when you enter custom mode (IE Track Mode), to "hacking" the ambient lighting to change color based on drive mode, and expanded capabilities such as seat memory. There's a ton of development, it uses the massive ATMEGA2560 microcontroller as the ATMEGA328 I used in the KSDM3 is unable to handle that many input/outputs. as far as timing goes, I don't have a prototype yet, I plan on ordering some engineering samples and testing them before the end of the year. There's a ton more math, and I still need to translate the CANBUS commands so the ambient lighting doesn't revert back moments after the command is sent. here's a bit of a teaser of what the final product will look like:
(50mm x 50mm)
9 channels of input/output memory or triggers (marked with ->)
  • Drive Mode L
  • Drive Mode R
  • ISG
  • Autohold
  • Park Signal -> EPB
  • Heated Driver Seat
  • Cooled Driver Seat (or Heated Passenger Seat)
  • Heated Steering Wheel
  • (Drive Mode==CUSTOM) -> Traction Control
This thing is an absolute unit, and I want to pack it with as many features as possible, so we are looking at months. but the KSDM3 will be ready in the next week on my website
(50mm x 50mm)
  • Drive Mode L
  • Drive Mode R
  • ISG (Idle Stop and Go)
  • Autohold
  • Park Signal -> EPB (Electronic Parking Brake)
Damn really good stuff. Can’t wait for the ksdmpro
Subscribe...
I'm all in for the Pro. Most interested in two things... 1. Drive mode 2. Traction Control, Stability Control. Waiting in line at the track can be daunting, especially when you have to start and stop and every time having to go through the whole sequence. I'll keep my eye out for the finished product.
(50mm x 50mm)
  • Drive Mode L
  • Drive Mode R
  • Autohold
What's your website address?
I'm just catching up here. This is awesome! I already have the ISG/AUTO HOLD memory module from another company installed. Will I be able to install just the DRIVE MODE memory module?
consider using a samd21 or samd51 instead of the atmegas. arduino support is excellent, it is orders of magnitude faster than the atmega.
