DGambit
- Mar 29, 2020
That’s a 3.3tt I’m assuming?I have a dyno sheet from the aem intakes and its 17whp and I think 15 tq
The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
I haven't heard anything about the HPS intakes, but this is the first I'm hearing about that orientation being preferred in DIY setups. Seems like you'd be guaranteeing hotter air by pushing them further into the engine bay. Not that it would be much different, but likely at least a little hotter. Just my 2 cents.Has anyone tried the HPS intakes? They look nice and are in the orientation that seems the best according to the diy community. I was going to get the velossa tech snorkels regardless of what intake I get outside of the JT because they come with new snorkels. I'm more than willing to be a guinea pig for the forums unless some people have some underwhelming/horror stories about them.
Injen would have been my choiceHello everyone,
If I could ask for some help on what would be better to get for my Stinger.
Im on the fence between AEM and Injen.
Reason is I'm stuck between these 2 is that AEM is cheaper and reading from somewhere here in the thread (I think, or in youtube) that it gave about a 18WHP/15TQ increase.
But with the Injen, it gives a 18WHP/23TW increase, and I've noticed on youtube the "Whooshing" sound from the turbos sound significantly louder, which I totally want.
I've seen here that having the heatshield is important for the intake is important, which AEM has, but supposedly it hasnt been much of a difference with the injen intake.
Not unless somebody has any other input in what would be better.
Would it be better to get the AEM then get the updated blowout valve if I wanted more whoosh sound?
Im so lost. Help!
I’m happy with my aem intakes..they’re are both going to sound similar anyway and comparing the dyno numbers isn’t accurate.Hello everyone,
Im so lost. Help!
So I don't know that I can answer all of your questions, but I can provide what little insight that I have. I've got the AEM intakes and I really like them. Take power gain numbers with a grain of salt because results may vary.Hello everyone,
Im so lost. Help!
I have the AEMs and they are very noticeable when you step on the loud pedal. But with any open intake you won't need to change the BoV's.Hello everyone,
Im so lost. Help!
I think it's just the heat. I'll lose an easy .3 to .4 seconds off my 0-60 in 95 degree weather vs 50 degree weather. Also remember that your car will adjust performance down to protect the car much faster than up.Has anyone had experience with feeling like their car is slower with intakes on? I installed aem intakes a few days ago and it seems like all my pulls are extremely lackluster. Now, it has been tits hot outside ever since I installed them but even in the morning on my way to work the car seems to be much more tame. I did not disconnect the battery, I was going to do that when I install my new spark plugs this week.
I feel the same way, installed AEM intakes about 1.5 months ago (disconnected the negative terminal also) and car is not as responsive as used to be with stock airbox. Thinking about putting the stock units back on. Disappointing.Has anyone had experience with feeling like their car is slower with intakes on? I installed aem intakes a few days ago and it seems like all my pulls are extremely lackluster. Now, it has been tits hot outside ever since I installed them but even in the morning on my way to work the car seems to be much more tame. I did not disconnect the battery, I was going to do that when I install my new spark plugs this week.
Was the temperature cooler before you put the intakes on? I recently dropped 40lbs of wheel weight with new wheels and saw a .2s increase in 0-60, but it's only because it's been WAY hotter out since the day I swapped the wheels. I won't know if they actually made a difference until the temperature drops at least 40 degrees and stays there for a few days.I feel the same way, installed AEM intakes about 1.5 months ago (disconnected the negative terminal also) and car is not as responsive as used to be with stock airbox. Thinking about putting the stock units back on. Disappointing.
Yes it was definitely cooler. I'm sure temperature is a factor that why I was thinking about going back stock air box because it completely enclosed and only source of air from opening from top front. The engine bay get really really hot and I "feel" like the AEM is drawing in all that hot air from the engine compartment especially because I don't have a snorkel up front. I do want to add a snorkel but hesitant because it may draw in water when it rains. I'm not planning on heavily modding the car so should have just got couple of the K&N panel filters. I don't know...Was the temperature cooler before you put the intakes on? I recently dropped 40lbs of wheel weight with new wheels and saw a .2s increase in 0-60, but it's only because it's been WAY hotter out since the day I swapped the wheels. I won't know if they actually made a difference until the temperature drops at least 40 degrees and stays there for a few days.
I went back to the factory airbox. Pulls are extremely hard again.Yes it was definitely cooler. I'm sure temperature is a factor that why I was thinking about going back stock air box because it completely enclosed and only source of air from opening from top front. The engine bay get really really hot and I "feel" like the AEM is drawing in all that hot air from the engine compartment especially because I don't have a snorkel up front. I do want to add a snorkel but hesitant because it may draw in water when it rains. I'm not planning on heavily modding the car so should have just got couple of the K&N panel filters. I don't know...
Yes sir, weather stripping on. Comfort mode feels like Eco mode now...I have to stomp on the gas to before its shifts down and start pulling. I remember gas pedal being much more sensitive with the stock air box. I have no empirical evidence of course, I just remember it pulling much harder with stock airbox and gas pedal being more sensitive. Maybe its all in my head. I bought my gt2 new this past March so maybe its just way behaves in hot weather. Going to order two new factory hoses that come off the factory valve thingy (where folks put aftermarket BOV) and put factory airboxes back and see if it was all in my head. I had to snip these hoses to make it fit AEM. Anyone have part number for these hoses?If you installed the boxes with the weather stripping there's no way for much, if any, hot air to enter. The AEM's pull air from the same spot the factory boxes do.
Opinions differ but AEM, Injen and Johnny Tig all seem to be very popular. Personally I went with AEM because of price, ease of install and maintenance, supplied heat shield and reduced heat soak.What intake is the best option for the 2020 GT1 ? K&N? Or would someone recommend a different one?
