you had to take off the bumper or can the tips be slid off? if the bumper comes off, there is no electronic components in the bumper to look out for?
i just received mine and plan to put them on.
For no trimming on the stock bumper area you want size A out on the link I posted.Anyone have a working link besides these? Looking between vendors to see shipping and price cost differences.
I have a 2.5" exhaust pipe (63.5mm) so what size would be the best from the oval ones so that its' a perfect fit or requires as little trimming as possible?e
I am having my xforce exhaust tips extended to fit inside the oem tips.... hopefully that stops the drone through the car.. if it doesnt fix it..im not sure what else I can do to stop it apart from removing it and selling the whole system and going back to stock.Has anyone had success in minimizing drone by just weld tips onto the existing pipes? My xforce fits about 20mm Into the existing factory tips at the moment would you suggest extending them say 100mm into the existing end pipes?
You'll need to extend the tip to the point where its close to the fake tip exit. The other option which most people have done here, with after market exhausts, is to get aftermarket tips. Theres plenty of links on here with tips to get.I am having my xforce exhaust tips extended to fit inside the oem tips.... hopefully that stops the drone through the car.. if it doesnt fix it..im not sure what else I can do to stop it apart from removing it and selling the whole system and going back to stock.
I ended up ordering aftermarket tips from AliExpress from what I have read online hopefully that should minimize the drone.I am having my xforce exhaust tips extended to fit inside the oem tips.... hopefully that stops the drone through the car.. if it doesnt fix it..im not sure what else I can do to stop it apart from removing it and selling the whole system and going back to stock.
If there are issues with drone (or you just want it even quieter inside after aftermarket tips) even then there is a few things I would suggest:I ended up ordering aftermarket tips from AliExpress from what I have read online hopefully that should minimize the drone.
The solution in my post above did not solve the drone that was created by the pipes being openly inside the OEM Tips, it still creates the echo but sound deadening makes it softer and absorbs some of that.The place im taking it to is going to centre the xforce tips so they fit perfectly inside the oem tips... I just want to try and keep the car looking as stock as I possibly can... don't need to alert those pesky cops nowadays...If this is successful i will try the AliExpress tips.
I'll rephrase that for your nitpicking purposes then: the exhaust tips are the solution for a large part of the problem, sound deadening helps soften the remaining part.Where's the solution? I just see some casually applied material.
When your tips arrives and you fit them.. can you let me know how well they work for you ?I ended up ordering aftermarket tips from AliExpress from what I have read online hopefully that should minimize the drone.
Shall do. They are still in China ATM delivery should take about 2-3 weeks.When your tips arrives and you fit them.. can you let me know how well they work for you ?
CHeers.
did you get the akropavic type? ive got them and they've reduce my drone to 0Shall do. They are still in China ATM delivery should take about 2-3 weeks.
mmm... I might wait and purchase these tips then get the xforce tip centred at the rear and fit these at the same time. The one question i have then, is what diameter do you get for a 2inch tip ? 51mm ? Then the exit side would it be 76mm so you dont have to shave any of the rear bumper off ?did you get the akropavic type? ive got them and they've reduce my drone to 0
I got oval type tips like the OEM ones are n carbon fiber (look) don’t think there real for that pricedid you get the akropavic type? ive got them and they've reduce my drone to 0
The outlet from the xforce is 57mm and I went with oval tips that match the existing (80mm tall x 105 wide)mmm... I might wait and purchase these tips then get the xforce tip centred at the rear and fit these at the same time. The one question i have then, is what diameter do you get for a 2inch tip ? 51mm ? Then the exit side would it be 76mm so you dont have to shave any of the rear bumper off ?
