Gtecko
Birthday was May 5th ... am I too late for this ?!
The $99 one is unlikely soon because they did that to offload some of their older devices. Right now, the best discount is the Kato (15%) code. But there may be another one-day 20% off code coming soon. I get to do that once in a while through my IG.was off that week and never checked the Forum ... Do we know if the $99 sale will be back on ? @Kato_the_kia_stinger any help would be greatly appreciated #Maybirthdays #Taurus![]()
Can’t wait to get your feedback! Did you use a discount code?I received my Bluetooth 9s on Friday (seven days from order, thank you!). Installation was a snap: remove throttle assembly with 2x 10mm bolts, power up then scan the UPC code for registration. 15 minutes, tops. Testing begins tomorrow, it's raining in Nor-Cal today.
I just got it now, which is weird considering it is a holiday here in Canada.
I'm about to install it, but I have read that for other pedal remapper-type units, a calibration is necessary. I don't see a calibration in the Windbooster's instructions.
Is it just plug-and-go, or am I missing something?
If you unplug it the throttle will stop working. Are you getting a check engine light? Your post is confusing.I installed it, and in short, it works!
I have a question, though. I have the 4S, if I unplug it from the wire harness, but keep the wire harness in place, what happens?
Does the engine light to off? Remember the last setting? Normal operation?
Plug and go! Enjoy. Let me know how you love it!I just got it now, which is weird considering it is a holiday here in Canada.
Nothing happened when I unplugged the clicker from mine. It wasn’t the 4s, but it shouldn’t matter.if I unplug the 4s from the lightning wire of the included wire harness, but keep said wire harness plugged into the car, what happens when I start the car?
If the above happened, would the car still run? If not, what would happen (ex would the check engine light go on)?
The reason I ask is because I don't want to unnecessarily throw a code just because the small thing unplugged while driving.
Got mine today too, it shipped last Thursday from Hong Kong that is crazy fast. Are those nuts super tight or could I get them off with pliers?
