moinmoin
1000 Posts Club!
fitment industries claiming to run 9.5 square with no spacers
It probably depends on the design of the rim whether spacers are required or not.
While Fitment Industries speaks of 9.5” rims with 35mm offset fitting without spacers anywhere,
the one inch narrower OEM rear 8.5” X 19” rims with 46.5mm offset will not fit the front without spacers. I tried.
But spacers on the 8.5" rims allow me to keep the OEM look with wider and beefier tires.
With the spacers in place, I am now able to rotate the tires front/rear/cross wise and gained Michelin’s 70k km warranty,
while the staggered set-up only lasted 30,500 km – mirroring Michelin’s warranty exactly.
The pictures for my set-up:
OEM 8.5” x 19” rims, 46.5 mm offset, front & rear
Michelin Pilot Sport A/S 3+ 255 mm r40 19”
15mm hub-centric spacers front
5mm spacers rear
