Metalmania82
The spring was way big dont worry bout it. what I have found so far is running the 7mm id hose made no difference but its what tial recommends so keeping with it. I put in a red spring I had leftover from a tial mvs wastegate, its the same size as the stock black spring but slightly softer. It holds bov shut at idle from the solenoid but not from the manifold. Bov Sounds like it should about 95%. The black spring seems to have just enough force to keep it closed from manifold vacuum, I shaved the smallest amount off and it no longer held closed. What I'm wondering is the torque app shows -18 vacuum at idle which would suggest that we need the white or plain springs according to there chart, so what I was thinking is the dual sound I'm hearing when letting off throttle is the boost pressure pushing up with enough force to leak by and make the "weird" noise in that split second before full vacuum hits releasing the rest and making the "normal" sound. I'm going to try shimming the black spring next and prove my theory right or wrong
Makes sense in my head but mostly because I don't understand this subject 100%. But looking forward to what you figure out. And thanks for the update.
