Drone eliminated
I only have have the NGL axle-back mufflers but even they still have some mild drone at about the 1500rpm range. Which was driving me (but mostly my wife) nuts.
My fix was connecting the muffler ends to the oem tips, so there is no gap around it, allowing all the exhaust gases to exit out the back of those fake tips. Similar to post 525 above. But I noticed the exhaust length grows (forward to back) by approx 10-15mm when hot, so I used a combination of foam on the muffler backing plate and some rubber pinchweld seal around the front edge of oem/fake tips. This closes the gap, so they are essentially "connected" but the pinchweld seal allows the heat expansion movement. I had also stuffed acoustic insulation up under the rear bumper/guard area [but don't think this alone did too much at all].
I'll post some pics when I get around to it.
This has eliminated all my cabin drone .... and even though I had planned to install sound deadening sheets and acoustic foam internally to the boot area, as suggested... I don't think I need to now (for drone anyway) although these would/should improve the audio system quality and reduce road noise.
Good luck.
Love the tone, hated the drone.
