xot1
1000 Posts Club!
4~5 wide open throttle pulls usually do the trick.How do I "let" my ECU adapt?
The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
You should do longer WOT pulls. Your logs are hard to read. However by looking at some high boost intervals I would say that your timings are very low. Values are down to 7~8.
But let's wait Terry for a better opinion.
I uploaded the wrong Map5 logs, the Map3 ones should show better info, but take into mind kinda hard to hold WOT for to long without going over 90.
It started after 1 or 2 weeks of running with it, about 2 gas tanks later. I always run with 3-5 FluidOunces of lucas Octane booster. So equivalent to 95ish octane with 91. I expierenced it at first with number 4, than it happened in 3, and than 2 and than 1 and than it happened with it disabled, after I ripped it out the problem was fixed.
Independent test showed 15 oz in 12 gallons was 2-3 octane, i think 2.6 if my memory is correct.I don't know where you got this info from, but from my testing 15oz to a full tank seems to increase the octane by 2 AT MOST. For real octane improvements you should use products like Torco or Boostane.
Much closer to what I have experienced.Independent test showed 15 oz in 12 gallons was 2-3 octane, i think 2.6 if my memory is correct.
That's what Racechip said, than I sent it back and the returned it to me saying "all is well, try again" come to find out it still did it. I wanted a refund so bad..... now it's just a waste of space as I doubt I'll ever get it soldVery strange. Sounds like you had a defective unit or a bad connector since it occurred on map 0 and went away when removed.
That's wierd, I used a octane tester after dumping 5 ounces into a full tank and it returned 94.6 octane.. (Which previously didnt have octane booster in it)Independent test showed 15 oz in 12 gallons was 2-3 octane, i think 2.6 if my memory is correct.
That's pretty poor. I bet they didn't even test it, just visually inspected the connectors and returned it to you.
So, do I gotta do that everytime I start the car or just for the map or w.e? What are good numbers?4~5 wide open throttle pulls usually do the trick.
Whenever you change the type of fuel or do a mod that affects air flow.So, do I gotta do that everytime I start the car or just for the map or w.e? What are good numbers?
Oktis-2 octane fuel testerNot being a jerk, just curious. How exactly are you "testing" your octane?
It is a better log.How is this? Attached log
Map adjusts throttle response and possibly other things across ALL of the drive modes. I.E. switching between ECO, Comfort, and Sport offers no difference in performance, suspension and other things that these settings change I believe will change as intended.
