StingerLover
Thanks for all the tips!
I was able to successfully swap my plugs without removing the manifold. With a combination of socket swivels and extensions and a lot of patience, it took maybe 1.5-2 hours. Had coil replacement bolts ready to go, but the originals went back in without any problems. A huge help was a little magnetic screwdriver that came with my spark plug gap tool. That made it easy to extract and place the bolts. Putting the coil under the manifold back in was easy after first separating the top and bottom and then putting them back together once in the cylinder.
Overall, not as bad as I feared. I'm sure all of the advance reading helped with the mental preparation.
