Looks great ! Way to go McGyver !I wanted the OEM Stinger cargo mat but not available in Canada. Ordering from the US after shipping, duties, and rate conversion takes it to $250. Didn't feel right to spend that on a carpet so bought a pretty-good quality 4x6 rubber-backed floor mat and cut it to shape.
Yeah! Nice work, @corradoMR2!Looks great ! Way to go McGyver !![]()
did you make a template first ??I wanted the OEM Stinger cargo mat but not available in Canada. Ordering from the US after shipping, duties, and rate conversion takes it to $250. Didn't feel right to spend that on a carpet so bought a pretty-good quality 4x6 rubber-backed floor mat and cut it to shape.
Do you have Home Dept down there ?Very clever, you can even make your own floor mats the same way. Where did you buy the mat?
these are readily available as door mats at home hardware stores , even in rolls where you can cut to length , they are durable with rubber backing and usually are made of nylon etc perfect for trunk liners etcNo unfortunately, no Cosco in Perth either. What brand is the mat?
Try BunningsVery clever, you can even make your own floor mats the same way. Where did you buy the mat?
I think if you made a template out of construction paper or light cardboard it would be relatively easy to get a perfect fit .......................Just found one in Bunnings hardware store. $42 a meter (2m wide) same ribbed and rubber backed.
Done that and found it.Try Bunnings
That seems like a nice addition. Not bad...I was hoping these would have worked for the the rear seats to secure bags in the trunk , but they weren't deep enough or long enough , since I rarely have anyone in the back seats I'm going to try this out and see how well works , ceratinly should reduce the groceries spilling out of the bag all over the seat ........................OK wine bottles !! View attachment 2512
Thanks , I'm going to work on making my own hooks for the back though , the problem with this set up is the bags can swing , vs in the back they would rest on the trunk bottom .....................That seems like a nice addition. Not bad...
Your bags need belts.Thanks , I'm going to work on making my own hooks for the back though , the problem with this set up is the bags can swing , vs in the back they would rest on the trunk bottom .....................
I was in your same situation and I ended up getting the premium fully loaded you'll save between 10 to 12k the diffrence would be no brembo brakes and the V6 twin turbo engine if your not going to race go for the premiumI'm up in the air on if I should go premium or GT1. Money is a little tight since I'm in the military, Lol. It will be replacing a 2011 VW CC. Had VW's all my life but the Stinger is too gorgeous to pass up.
