From MikeysGT post:
MikeysGT said:
>I just went for a drive with a Bluetooth OBD2 adapter hooked up transmitting data to my phone
>through the Torque app. I found the 2 smoothest, flattest roads I could find around here and
>monitored throttle position with CC engaged at 55mph then again at 75mph. Every time I felt the
>surge I would make sure to watch the throttle reading. At 55mph it jumped up by about 2% every
>time. At 75mph it was much more apparent and jumped by 4% every time the surge was felt from
>24% to 28% or even 29% sometimes. For what reason? I dunno, I'm not a tuner, but if I can find ?
>data like this with an $11 adapter and 20 minutes of time, let's hope KIA can do the same and fix
>the logic.
I'm sorry to be slow, but if Mike is around, my question is: when you say it goes up by 2%, do you mean 2% increments or just 2% total? Because later in your post you talk about increases of much 24% and 28-29%, which of course seems like way too much. I suggest (since the Stinger is already so very customizable) they add a menu option for how aggressive the car responds when a lead car that has slowed the Stinger down moves out of the way, allowing the Stinger to speed back up to the set point.
