mull0263
Question for the group before I call the shop when they open back up tomorrow. I was planning to install the following:
225/40R/18 +35 18X8.5" in the front
255/35R/18 +40 18X9.5" in the rear
They mentioned they had some issues with the offset and had to change the tires due to rubbing - I just assumed they put the wrong tire on the wrong wheel and didn't think much of it until I started driving home and realized they mounted the 225 tire on the 9.5" wheel and there is a lottt of stretch. Does the setup above sound like it would rub? If so, would adding a spacer on the rear work? I do not want that much stretch on the rear.
