Ok guys, im happy to report that this will work. I disconnected the brake pedal switch just to see if it works before doing the switch bypass and it worked. I still wasnt able to get more than 5psi but it would hold forever and i was able to do a burnout as well.
If you want to test it, you need to have the car in drive and pull the ebrake and then disconnect the connector. If you ever leave drive you wont be able to go back until you connect it back because the car needs to see the brake pressed to go into drive or reverse.
It's worth mentioning that pulling the AWD fuse does a LOT.
Disables: "IBU, ECS Unit, AWD (All Wheel Drive) ECM (Electronic Control Module), Smart Cruise Control Module, Auto Transmission Shift Lever Indicator, Console Switch (Front/Upper), Blind-Spot Collision Warning Unit Left Handle side/Right Handle side, Steering Angle Sensor, Steering Tilt & Telescopic Module, MultiFunction Camera Unit, Crash Pad Switch"
so basically, your telling me to wire a switch through the fuse box to disable AWD, and another one to let me do a burnout... Man i might have to try this.......
But!
Does simply pulling the brake light fuse disable brake signal to ECU (versus "cutting a switch in" to the brake pedal switch wire)?
Or would cutting in a switch simply be easier?
Either way I would want a spring-loaded momentary switch (have to "hold" switch open/interrupt the circuit) to prevent me from inadvertently forgetting and not having brake lights :O
But!
I think tapping the brake pedal connector is better. It will be easier to route the switch to the driver and will not affect other systems in the car. We just need to figure out the correct wire that is going to the ECU and add a switch there.
There are five wires. Blue, orange, black and two green.
