Doel
1000 Posts Club!
right, in theory people should run better times than their "Mexico" draggy runsTrack comparison vs street. Prepped surface, Different story all together.
The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
Map 7? So like 21+ psi? Did you knock your way to that ET? LolRan a couple today. Roads are shit but I tried to haze em and get some heat into the tires. No power loss 1st run. 2nd run dumped right at the top. 0 to 60s were shit but I ran a good almost valid earlier in the day.View attachment 19312 View attachment 19315 View attachment 19316Got some logs this time with a iat wire.
map 5Map 7? So like 21+ psi? Did you knock your way to that ET? Lol
I'm assuming that's why it fell on it's face. Ran out of fuel.
Yes, but the comparisons are done on the same run. A track is going to give a huge advantage in traction compared to the street so we can assume faster times will be seen. The only thing I'm curious about is if the added traction benefits are going to outweigh the added cold air benefits we are seeing people get from the streetI dunno, every test I've seen between the draggy and 1/4 show the times to be really really close.
Map 5 is still 7psi over stock right and were you using race gas ?map 5
Yes, should be around 17psiMap 5 is still 7psi over stock right and were you using race gas ?
We put out 14psi stockYes, should be around 17psi
Something interesting to note is that all the JB4 equipped vehicles used 19-21psi maps to achieve their results.
The Lap3 ProTuned cars all used a 1.3bar(18.8psi max) map.
Does anyone know what the tork ECU tune uses?
What I like seeing is minimal mods with maximum performance![]()
Lol please show me a stock data log showing 14psi.We put out 14psi stock
Well being the beta tester for the ProTuner, I can tell you that you're 100% incorrect.You have that wrong. JB4 uses 15-17psi, Lap3 clearly states on their dynos they use around 21psi
I'll waitLol please show me a stock data log showing 14psi.
Jb4 has a big following. I understand what you are saying but if you think the sky is green try convincing the rest of the world it's not blue, going to be hard even if you are right.Here we go again. Anyone questions anything about JB4...out come the trolls. Damn, and I thought it was going to be different here .smh
