The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
That’s correct.So your talking about downpipes with primary cats gone?
I'm running full turbo back, catless primary and secondary with JB4. To prevent codes you need to use the passive delete feature on the wmi settings page. To do that in US you have to use a vpn app to connect to Canada IP, then set country in jB4 to Canada. Because jb4 is CARB approved for various models they cannot have emissions defeating features in US.
The IAT cable is is really simple. Took me 10 seconds. You need to go in and set 6Cyl to 20 (at least for chicagoland weather ( -3 tomorrow -_- )Overboost only happens occasionally when boost target and boost actual vary too much on lower maps in the cold air. A Given WGDC is making more boost catless so the difference between target actual is greater than normal. The solution is simply to run a higher map. I daily on map 3 and don't have any issues. I also have to still add IAT wire when should also add more commanded ECU boost and should address the issue as well, but its been too cold for testing. Once eWG is added to JB4 this will not be a probably at all on any maps or temps.
