Angelo In Seattle
Then why didn't you buy them?
Name is Casey not dude.
Casey, sorry I just saw your post now. Check your PM.
Here is a Picture of my muffler delete.
After that a had a lot of drone from 1200RPM to 2600RPM. I went back to the muffler shop and they install a drone tube, and after that it got 90% better. You can hear a little drone between 1800RPM and 2000RPM.
The sound is not as deep as with straight pipes, but not having a lot of drone worth it.
They cut off the muffler and installed an y pipe...I just looked at your pictures in more detail. I was wondering if the shop you took it to had just cut off the muffler and replaced it with a y pipe or did they unbolt it all the way and replaced it with non restrictive tube and a y pipe. I'm debating on whether or not I should get the SSR performance axleback or head to to the shop and get it done since it would cost about the same. In the stock system it has a restrictive area close to bolts but I can't seem to tell from your pictures if they were replaced. Thanks
I see. Much appreciated. Thank you.They cut off the muffler and installed an y pipe...
I PMd you a while back did you ever see it?Hi Angelo, your car sounds great! I live in Seattle, any chance I can check out your car in person some time? Maybe find out who cut your pipes?
Thanks Casey
I disagree I just got the deletes, cut off at the muffler and new pipe welded on there. I love it. Just got intakes as well and she’s a beast!From what i am seeing here is just go with the down pipes or your car will sound like shit. Seems like the performance gains are at the down pipe anyways right?
