Exhaust Dump valves have nothing to do with which map you run......if you on 92 octane you can run map 1 or map 2.......Denson will be fine just gap them coorectly .022-028 I gapped mine at .024.......FYI Just so you know the map you run is based on the fuel your running not mods.......
So in the thread related to the dump valves, there has been some discussion. Alot of people have seen that it takes the ECU quite a while to adapt to airflow changes and get you the horsepower you should have from the mods. What I'm asking is, does the JB4 help with this? It wouldn't make much sense to run dumps if every time you open them, you have to run 10 times before seeing the gains....
