Exhaust Dump valves have nothing to do with which map you run......if you on 92 octane you can run map 1 or map 2.......Denson will be fine just gap them coorectly .022-028 I gapped mine at .024.......FYI Just so you know the map you run is based on the fuel your running not mods.......
So in the thread related to the dump valves, there has been some discussion. Alot of people have seen that it takes the ECU quite a while to adapt to airflow changes and get you the horsepower you should have from the mods. What I'm asking is, does the JB4 help with this? It wouldn't make much sense to run dumps if every time you open them, you have to run 10 times before seeing the gains....
You’ll get gains instantly, maybe not peak gains but you’ll see gains. Post turbo gains usually are quicker than pre-turbo ones.
Maybe Terry can chime in but regardless you should see improvement when your running them. You may not get optimal performance if you keep constantly opening and closing them.
Reduced back pressure allows the turbo to work more efficiently, so less WGDC will be required to hit the same boost target. There isn't much adaption needed. These cars run full time closed loop boost, timing, and AFR.
Thanks terry!
Thanks terry!
I'm still confused. This doesn't explain why people are seeing that gains are basically nonexistent on the first pull, then slowly "adapt" into full power. Is this just an intake side thing? I've seen it mentioned on a few threads where people put mods on mid dyno.
Your response leads me to believe that as soon as the valves were opened, the system would sense things in not even a second and you would have ~25 more whp? Extremely rough guess but you get my point.
Appreciate the response!
Not sure I feel a big difference everytime i open them.
There are videos on gains from cutouts heres one i found. This is not our platform but everyone will be different depending on restriction and we have ALOT of it. I plan on dynoing my car within the next month or so. I'll have the charts of them opened and closed.
There is some adaptation on all car on the intake side. If you’re pulling more air, there may be some timing pulled before it adds some... but we are talking about ~3 wot pulls and maybe 8-10hp at a peak spot. They still gain 5-6 across the band until that happens.
The exhaust side of a turbo car is just different. A turbo is already pulling a lot of air from the front...it would take extreme restrictions to see gains from an intake to match what we see from the DP’s.
However, on the exit side, in simple terms, has much more restrictions and the air has already been accounted for... mods on this side are just helping the efficiency of the engine to relieve itself. These mods show almost instantly... since there’s no need to remonitor the incoming air. A turbo car loves freedom on the exhaust side.
Hi StungBlueGT2
I took the car for a run this morning and logged you can see the CSV files on the link below on N54 tech.
Kia & Hyundai JB4 - Page 45 - N54Tech.com - International Turbo Racing Discussion
I'm running Map 5 with 30% plus of ethanol with fuel wires and the V6 firmware and the car only spun the wheels a little of launch the below snap shot is taking of with launch control.
Appreciate peoples thoughts to work out what may be wrong
Hello D-C,
Terry is the expert and he would know best, but still think you should easily spin the tires with any extra power.
I’m sure the springs are helping and just have to do some dragy or track runs to test your 60ft times. Who knows maybe you’re running some of the quickest 1.9s and don’t even know it! I bet a lot more RWD Stingers will buy the springs if it makes that much of a difference. Keep us updated as I would love to have less spinning myself.:thumbup:
Base stock map 0 and fbo besides cat back map7. No done yet
Thanks for sharing and is this from a dynojet, or Mustang dyno? Also, what is your elevation?
Nice gains but I’m just curious why you’re making less power than Terry’s Stinger did on lower maps with stock exhaust & all 4 cats.
You gained 87whp & 106wtq with FBO, e30 & map 7. But Terry is gaining 106whp & 128wtw with only intakes, e30 & map3.o_O
I know you can’t compare different dynos but the gains should be similar or even higher than Terry’s I would think. Any ideas?
Thanks S
Hello D-C,
Thanks StungblueGT
You never know she feels quick, I'm just about to buy a dragy waiting to see the burger intakes and I might bundle it up because shipping to Australia isn't cheap.
Will report back soon Cheers !!
He has a load Mustang dyno. So the peak numbers are going to be a lot lower.
We’re going to a dynojet next week. We’re waiting on the wmi kit. Depending on time ( because is not our dyno) well do more comparison runs.
@Terry@BMS quick questions about the following quote off of the Stinger Forum Store (with Sal)
"462 horsepower and 531 pound feet of torque – at the wheels… "
How were those numbers attained, as far as what mods if any.
I posted the details with the dyno in a thread on this forum. :)
Back somewhere in this thread or a whole different one?
Just wanted to say that the latest firmware update is excellent! Downloaded/installed it last night before an hour drive on the highway i'm really liking the new "throttle response" in Comfort and ESPECIALLY in Sport. Great job guys!
