At this point in time we're comparing an ECU tune running 0.02 seconds quicker in the 1/4 mile than a piggyback tune, but the piggyback is trapping 2-3 mph faster. For all intents and purposes (AT THIS CURRENT TIME):
Tork is QUICKER due to their cars having more traction (indicated by lower ETs)
JB4 is FASTER due to their cars having better power / weight (indicated by trap speeds and back half mph gains)
I agree, but there are concerns that I have.
No one has seen my car and what it can do on methanol. This will be a game changer for the community.
Next, if you look atthe logs getting posted, and compare them, then look at the comments being made by Terry... we have another problem.
Just a few days ago Terry claimed that the ignition drop was to protect the transmission... now, his logs are showing little to no ignition drop. So, did Terry just dismiss the transmission protection in the sake of getting numbers? Or, was Terry making excusses for why our car was faster than his?
Look at ignition chating, its inherently higher at the same RPM points. Look at boost levels, also higher. Look at AFR's... running a bit leaner thank us.
So, if we are just talking about a few 100'ths of a second but there is a clear advantage from one of the cars in the logs posted and the
mods on it. I think this is huge.
What I am stating is this. Could you imagine, my mod list, add methanol, more boost, higher octane, more ignition timing, leaner AFR's with a better tire and light weight wheels? As a tuner, I would kill to be running with methanol right now, and soon I will be.
For TonkaBob's car. I bet we have another .2 that we can take off his times. No other
mods. 11.7 is what I want to achieve with his car as is, and then we will add additional power adders and see just how far we can go into the 11's with his car.
My personal goal is to run 10.9 with my car on the stock turbos. Then, we move forward with modified stock turbos, and hopefully run a single digit pass!
