Good info Terry. If boost drops when cold, what is the optimum IAT to be fastest?
I've been running mostly on cold days. Did run the 3.87 at 50 degrees but the 1/4 miles were low 30s.
On this run IAT was 65 at start 60 at the end. I'm logging the boost / vacume gauge so it goes -10 or what ever. (My log starts during LC so boost near 0) Also have the option to log absolute intake pressure.
The bottom chart axis is time, just the data point count. Logging every .25 seconds.
On the second graph speed is on the left on the scale that goes to 125.
There is no easy solution there as to what is fastest overall, octane is also a factor. You will definitely want to evaluate the tuning under warmer weather also. Since the ECU is load based if not set properly the boost could climb much higher than expected as temperature does. Tuning is a multi-dimensional puzzle.
In terms of boost I'm not familiar with your logging tool, it may or may not be accurate in the logs, depending on the specific sensor being logged and whether it's zerod out for absolute boost numbers. What does the value read with the engine off, ignition on, for example?
