I just got my Ark Grip exhaust installed a few weeks ago and recently added the SSR performance down pipes with secondary cat delete. With this combo it sounds similar to the BMW video posted above. Interesting side note, the drone actually got quieter with the down pipes added. Overall though the whole exhaust got louder and at WOT people will hear you from several blocks away. The only trouble is you can only WOT for a few seconds or you'll be at 100 MPH. Even though there is less drone with the down pipes I still ended up completely covering my trunk with sound proofing and went as far as removing the internal lining and filling the fenders with foam material. I also covered up all the holes in the framework and filled the area around the battery with sound deadening foam. Makes a huge difference and the drone is much quieter now. Very happy with the sound and REALLY happy with the added performance.
My Stinger is AWD and in comfort mode I can hit the gas around a corner and kick the rear out (dry road). In sport mode on wet roads it can get a little dicey but very fun if you don't go too crazy (AWD drifting anyone?). I noticed a bump in low end torque with the down pipes and upper end torque with the cat back exhaust. Going 60 and gunning it throws you into the
seat now. No official 0-60 times or dyno numbers but with intakes and LAP3 at 93 I would estimate that I'm at over 420HP at the wheels. I'm going by other people who have dyno results with similar
mods have posted. The car is crazy fast now. Last thing I want to do is spare ECU with an actual tune from Tork. If you are wondering, I do have the correct
spark plugs and oil catch cans installed as well. I would not run this setup without either. Not a lot of slop in the pistons/rings, minimal blow by from the small amount of oil I'm getting in my catch cans.
