< -- My 06 spec b (stage 3). Over 5 years ago I upgraded to slotted DBA rotors, SS lines and StopTech pads. I thought I was bedding the pads in sufficiently, but deposits recurred. The Brembo bedding instructions seem insufficient IMO.
Please see the last 5 'whitepapers' here bottom of page 1:
Resource Library
After I thought I had bedded the brakes (calipers/pads/rotors are a system) properly I did a spirited drive and didn't let the brakes cool before stopping for the night. The next day there was a horrendous shudder when braking and deposits were very evident to the eye and you could feel them on the rotors as well. So - I did the process again following more closely the seemingly aggressive guidance above and based on older StopTech info. If you think you're overdoing it, and quit when you can smell the hot brake (system), you may not have adequately completed the process. There should/could be SMOKE! And plan it so you don't have to come to a complete stop, until you can drive a while to cool the "system." I've had no problems since the aggressive bedding process. Based on all this madness posted, I will likely be doing the same to my Stinger...
when I obtain one...
Getting ""warped"" rotors turned/machined/replaced will just necessitate the bedding process be done again.
@MerlintheMad - you must be lucky or do you 'engine brake' a lot?!
