Where the blow off valves sit.
I want to say there was some discussion about this a while back. If I remember correctly, the older builds had metal and they switched to plastic at some point. I’ll see if I can find the thread.
I wonder if it was for performance or cost savings.
Also what's up with your merge pipe? Is it plastic?? Or am I just seeing things?
Edit : no it's for sure different than mine. View attachment 40370
Starting with MY 2019 some Stinger GT have the plastic merge pipe. I owned 2 model year 2019 and 1 had the metal merge pipe while the other had the plastic one.
Does anyone know if someone makes a CCV oil catch can for the 2.0t? I’m planning on adding the PCV catch can but would like to do the whole system.
What is this black gunk on my engine? Gasket is wearing down or ?
That’s good, well it’s probably like I stated in my first sentence, the area doesn’t appear “wet”.
You have a photographic record now so I would wipe it all off, clean the area & monitor it & check every week for change.
yeah my entire engine needs a good clean, its super filthy.
Started to instal these with the very helpful non existing instructions...15868703018502555067770237004650.webp
you posted WAY better picture on FB :D:D
I'll probably do a proper write up about these soon since there is Zero info anywhere about them.
